The Ortho AllClear Cordless Power Mister charging cord requires a 5V DC power supply with a micro USB connector. You can purchase a replacement cord with these specifications at most electronics stores or online retailers. Make sure to verify that the voltage and connector type match the specifications of your device before purchasing a replacement cord.
If it is permanently attached, take it to a repair shop and let them replace it. If it's one that unplugs right at the unit, take the cord to a repair shop and ask to buy a replacement cord.
Make sure the replacement cord is made for that unit if it has a plug/socket at each end of the cord and if it's permanently attached, make sure the replacement is same gauge, or heavier gauge as the original.
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
I've never seen the ad for a weed thrasher but, as far as a replacement cord goes. You can buy a extension cord of the same size and install it. Just cut off the end. The wires within the cord need to be the same size or bigger, never smaller. Also it's important to replace a 3 wire cord with a 3 wire cord. You can use a 3 wire cord with a machine that came with a 2 wire cord, just cut off the green wire at the machine end. Your wire colors should be white, black, and green. Black and white are your power wires and green is your ground. Usually black and white are interchangeable but, on occasion switching them may make the unit run backwards so install them in their original position. Write down where they where hooked up and install your new cord in the same places.
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the pot with you to make sure you are getting the correct cord.
