I assume you are refering to you a/c compressor .----- the fuse covers under the hood & on driver's side dash should have a listing on the back side , if you don't have the covers try checking for a repair manual at your library . these fuse & relays don't normaly go bad unless the compressor is bad or a short in wires . if you a/c does't work at all it's probaly low on freon charge, there is cut-off swithes built in to the system so the compressor does't run with out lubercation that is carryed by the freon.
