Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Drip pan overflowing on Kenmore side by side refrigerator.
Posted by halfmoonbay on
Shengah
    New Friend:
    Problem Solver:
  • 12 Answers
Sounds to me like your defrost heating element is shot. Unplug the refrigerator. Empty out the freezer take the screws off the back panel and remove panel. Defrost the cooling coils with a hair dryer. At the bottom behind the shield you will see a glass tube. Unplug it and bring it to your local app repair shop and let them match it up because making the phone call with your make and model doesnt always work but bring those numbers with you as well.There was some models made with single heating elements that had to work twice as hard to get the defrost job done so they burned out more often. Your repair store will probably have a new dual tube for ya. Hope this helps. Almost forgot..Make a temporary plug with a paper towel and stick it in the water drain just in case you drop a panel screw down the drain(not fun) good luck!
Posted on Jul 04, 2011
Refrigerator overflowing water
If the drain pan is overflowing, they are made to catch drips. But if you overfill the glasses a few times a day the pan will overflow because there is no drain for the pan. You have to soak it up with a sponge if this is the case. If its leaking then there is a solenoid in the back of the refrigerator that is sticking, if so remove the solenoid valve wire connectors, the water lines and the solenoid valve water control valve and replace. Local appliance dealer should have one for about $60.00 or so. They make a universal solenoid water valve that fits most refrigerators. Good luck I hope this solves your problem. Please post a solved comment on fixya, so I receive credit for the solve. This will increase my ranking on fixya.com That is how I get paid. By knowing I am helping someone!!!
Apr 11, 2014 | Kenmore Refrigerators
Water is dripping into pan under fridge and overflowing onto floor. looks like water is dripping from filter at bottom. what can i do?
Check to see looks like the container is already full. You have to remove the tray full of water and then insert it again. It will happen again and again ( overflowing water) so you need to periodically check the container pan if water is full.
Also by checking periodically that pan, you will minimize rust build up. You will need to wipe around it with soft cloth or rags so the body of your refrigerator will not decaying due to rust built up. This will destroy the metal parts of the fridge.
Good luck.
Jun 25, 2011 | Kenmore Side by Side Refrigerator
Whirlpool 25.6 cu. ft. side by side with overflow pan underneath spilling over.
make sure that condensor fan motor which evaporates that water is running..
May 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Drain pan over flowing
The rubber seal on the water filter is bad . Replace the filter in the bottom kick plate . When the filter goes bad , water will drip into the drain pan , causing it to overflow .
May 12, 2010 | Kenmore 57029 Side by Side Refrigerator
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is leaking on the ground
Assuming you are talking about water leaking, if it has a drip pan to catch condensation, it may be full and overflowing or missing a drip pan allowing water to fall to floor. If it has an icemaker and/or cold water dispensor, it could be a connection leak.
Oct 08, 2009 | Kenmore Refrigerators
Water is steadily running/drippin into the drip pan...overflowing
The frirgerator has a defrost when it defrost it has to go somewhere check the drip pan and make sure it is not full.
If this continues then try checking the water line coming into the back and up the back of frig. try that first
Feb 26, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Sep 11, 2008 | Refrigerators
Refrigerator leaking water
There is normally a small shutoff valve installed in the water line servicing the ice maker; you might shut off the flow of water until you locate the problem.
Most drip pans can be slid out but it would be wise to lower the level with sponges or similar to avoid any more spillage than you already have.
If the 'knob' is centered it is probably the release knob for the grill, behind which is of course the drip pan.
Before damning the ice maker (although they are among the most unreliable devices known to man), I would pull the fridge out and examine the fitting where the water line is attached.
Any lime buildup or green corrosion around the fitting would imply that the leak is external to the cabinet and the leaked water is only accidentally making it to the drip pan.
If you haven't been getting blocks of ice in the cube storage bin, the shutoff valve is apparently working so you may get lucky locating the source of the leak.
Jul 07, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
204 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
