Question about Dehumidifiers
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your help gb
Posted by gbqc31ca70 on
A Miller
  • Dehumidifiers Master
  • 8,404 Answers
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Posted on Jun 05, 2011
Idylis dehumidifier 0526011 will not shut off even when is reaches it humidity level. How can I get it to shut off. The compressor stops but the fan keeps running.
this is a newer feature that a lot of units do now this is called air circulation mode !! try running on low it's not so noisy then
Oct 03, 2014 | Dehumidifiers
Why has it stopped running, but still shows temp and humidity?
I may have reached the humidity level that you have set it at. Press the HUMIDITY button until it says "Lo". That should put you into continuous run mode.
Good Luck.
Jun 09, 2014 | Haier DE65EJ Dehumidifier
Dehumidifier runs from low to high.does not keep same fan speed.
If you are operating the dehumidifier in continual mode, this is normal, based on the humidity extraction level you have the unit set on. It senses when there is humidity to remove and speeds up. When it has reached the level you have set it for, it slows down and keeps the air circulating, until it senses a need to speed up, again.
Hope this helps you. Thanks for choosing FixYa.
Jul 28, 2011 | Maytag M7DH45B2A Dehumidifier
My dehumidifier kenmore model 580.52650 is working fine but turn off and turn back on every three minutes it is this dangerous, any solutions ? THANKS.
I think the problem may be caused by the humidity extraction level you have the unit set on. (i.e. It's set to high). Lower the humidity extraction level to 35%. This will allow the unit to run longer and extract more humidity, before it either shuts off, because the humidity level has been reached or the bucket is full and needs to be emptied.
Don't forget, the air intake filter should be cleaned regularly.
Hope this helped you. Please let me know.
Jul 08, 2011 | Kenmore 54501 Dehumidifier
Is there any way to run automatically. . . where when it reaches humid per cent it shuts off? Can you rig to run for x hrs. per day and then shut off and restart the next day?
Norman, once the unit reaches the extraction level you have it set for, the unit will turn OFF automatically. However, depending on the humidity level in your home, it may take several cycles of running and emptying the bucket until it reached. After that, it should turn OFF, once the level is reached. Then when the humidity level rises above the setting it's on, it will start up again.
Since your unit is a Manually Controlled unit, there's no safe way to "rig' it to run on with a timer. The plug in wall timers are not rated high enough to handle the load of the dehumidifiers operation. Trying to use one, would fry the timer and possibly the dehumidifier.
If you want all the features you mentioned, you will need to purchase a new electronically controlled dehumidifier.
Jul 05, 2011 | Amana D545M Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
We can hear the fan running and then the compressor, but little to not water produced; sometimes we can hear it click on and then off; the fan seems to be running a lot...
You may have the humidity level set to high. Usually anything above 50%, will show little results, unless your house is flooded.. Turn the humidity setting to the lowest level that your humidifier has
and give that a try.
The fan runs a lot, because it's designed to almost constantly move the air around. That way, if the humidity level rises above the setting on the dehumidifier, it can sense it and the compressor will turn ON.
May 17, 2011 | Amana D545M Dehumidifier
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
New unit, try using in basement. nothing happen, should humidity settings be high or low? Dose humidity level be high? In the bucket whats the plastic cup about? do something alow water to enter bucket?
If you trying to remove humidity, the setting or percentage of humidity to you want to remove should be set low. it's actually the humidity that will be left in the air. In the Hot Summer months, you want lower humidity, as opposed to the Winter months, when you want higher humidity.
"Plastic cup inside the bucket" - that's got me stumped. But, I suspect, it may be a float valve to turn the unit off, once the bucket reaches the full level. The water enters the bucket through a drain tube or hole from inside the dehumidifier, above the bucket.
By best advice, since this is a new unit, that you recently purchased, is read the Owners Manual/User Guide and become thoroughly familiar with the proper operation of your Dehumidifier, as well as how to properly maintain it. As, they aren't maintenance free.
Apr 15, 2011 | Haier DE65EJ Dehumidifier
Can most heat pump type air conditioner/furnace have a dehumidifier added to them? We are dealing with very high humidity in our 1100 sq. foot apartment.
Yes, but they are expensive! The unit is mounted into your air handler & a humidistat installed. Walmart dehumindifier a lot cheaper. I use one on my 1600 cuft home real well. You can set humidity level, unit will shutoff at that level. They come with an internal tank & can be plumbed to an external drain. Winter humidity should be @ 49%. Dehumidifiers also create hot air.
Nov 03, 2009 | Dehumidifiers
Dehumidifiers Logo
182 people viewed this question
Top Dehumidifiers Experts
Marvin
Marvin
Are you a Dehumidifier Expert? Answer questions, earn points and help others
