Question about Teac AG-V8060 Receiver
Teac AG-V8060 Receiver No sound. If I turn up the volume all the way I get a whisper of sound from the speakers.
Posted by jwheatley on
  • vidit sharma Jun 04, 2011
    else your speakers went out or you previously used it at a higher volume ,higher than its capacity
David Dunn
    Brigadier General:
  • 8,546 Answers
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Posted on Jun 04, 2011
Why does my Teac receiver only light up the volume, then shut back off?
Your receiver has developed an internal short circuit and the unit is shutting down to prevent further damage. You might want to check the power supply for problems since it is a hard working area and prone to failure.
Sep 01, 2015 | Teac AG-V8060 Receiver
Why dont i have sound
First , make sure the speaker switch is ON
Second , make sure no TAPE MONITOR function is on.
3rd, Make sure ( if there is a Mute switch) , turn that off.
If still nothing, try headphones and see if something comes through
Feb 27, 2015 | Teac AG-V8060 Receiver
The sound through the speakers is very faint. Why can't i get more volume?
IS there a tape monitor switch on the Front Panel?
Is it ON?..Turn it off
Is there a MUTE function on the unit?...If so, turn it off
Try those 1st
May 24, 2014 | Teac AG-V8060 Receiver
I own a TEAC AG V1020 receiver. One channel keeps cutting out then and back in after a few minutes. When I give the volume control a quick twist louder then back down, the channel returns for a few minutes...
Turn it off and vigorously operate all mechanical controls throughout their ranges many times with special attention paid to any Tape Monitor or other rarely-used controls.
Jan 10, 2011 | Teac AG-V8060 Receiver
Lost manual..do not know what is the difference sound surround
Hi use this link to download the manual .
manualnguide.com/manual/teac-ag-v8060-receiver.../page/2/.
Take care.
May 18, 2010 | Teac AG-V8060 Receiver
How do you reset the blinking protect banner on the ag-v8520?
Try disconnecting the power cord then disconnect the speakers. Plug the power cord back in then hold in the power button until the unit "clicks." Then disconnect the power cord and reconnect the speakers, then the power cord and turn it back on.
Jun 13, 2009 | Teac AG-V8060 Receiver
Receiver Blinks PROTECT
how many speakers have you got on to it
Dec 07, 2008 | Teac AG-V8060 Receiver
Teac AG-V8520
same problem exactly
Oct 13, 2008 | Teac AG-V8060 Receiver
TEAC AG-V8060
Do you already check the Thermal fuse on the transformer.He be on the primary side between two pins ,he been protected with plastic cover.
Nov 30, 2007 | Teac AG-V8060 Receiver
Teac AG-V8060 Receiver Logo
430 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
