REMOVE THE CHAIN
COVER AND THEN YOU WILL SEE A NUT OR TWO THAT IS THE NUT THAT TIGHT THE CHAIN PLATE.UN TIGHT IT AND PULL THE CHAIN PLATE TO THE FRONT UNTIL IS STRETCH.BE AWARE THAT TO MUCH TENSION WILL NOT WORK SO LEAVE A GAP OF 1/4 INCH BETWEEN THE CHAIN AND THE PLATE.TIGHT IT BACK.
If you need more help post back!
Thumbs and testimonial are welcome!
All the saws I use that do not need the cover removed to tighten the chain. If the tightening parts are in the cover you can't adjust the tension with the cover off Other saws the pin is on the saw side To tighten the chain there is a pin that fits into a hole on the bar. Turn the adjusting device to move the bar forward to tighten the chain. If you get it too tight it will not move.
