Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Firstly make sure your PSP-3000 or TA88v3 PSP-2000 has PSP Firmware
5.03 installed. Check in your PSP XMB go to Settings/ System Settings /
System infomation. If you don't have PSP 5.03 installed
download it
here.
Create a folder called UPDATE in PSP/GAME on your memory stick and
place the eboot from the archive into the folder. Run the 5.03 Firmware update from GAME / Memory stick and you will have 5.03. The firmware required to run ChickHEN.
Now download the
ChickHEN R2 release from
here.
Open the CHickHEN R2 archive and place the folder inside Slim with gif
images into your PSP memory stick location like so PSP/PHOTO (later it
will be PSP/PHOTO/ChickHEN). Now place the h.bin into the root of your
memory stick pro duo. Where the folders PSP, MUSIC etc are located.
Ok
next step place the memory stick into the PSP. We have found this step
helps ChickHEN boot with less attempts, go your PSP XMB, to settings and
Restore Default Settings. Your PSP will reset, now go back into
settings and turn off UMD Auto-Start and UMD Cache. We found ChickHEN
loads in 2-3 goes after doing this.
Now go into Photo / Memory
Stick and ChickHEN. And wait, you will see five egg giff images, these
will start to load thumbnails. Your PSP may freeze and reset. Just keep
retrying and ChickHEN R2 will load up....But if you see flashing colors,
your PSP will reboot into ChickHEN your homebrew ready!
With
ChickHEN R2 loaded now starts the fun part. (P.S You can put your PSP
into standby now so you don't have to go through the whole process
again)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
