Question about Nuance PaperPort 12
Paperport 12 "Cannot communicate with
Steve Baxter
    New Friend:
Nuance's fix for Paperport 12's "Server busy" error (downloading and copying an updated file) also fixes this "cannot communicate withthe all-in-one indexer error". See Nuance's fix at:http://nuance.custhelp.com/app/answers/detail/a_id/5949/~/%22server-busy%22-error-when-using-the-all-in-one-search
Steve Baxter
Forbes Baxter Associates
www.forbesbaxter.co.uk
Posted on Jul 03, 2012
1helpful
Unable to scan with Brother DCP-7065 DN with Paperport 14
You should first run the Scanner configuration for PaperPort.
1helpful
When I try to scan, the scanner setup window will not open and nothing will scan
first reinstall operating system
and after it install scanner setup if scanner setup not run
then
downlode another setup and install it
problem will solve
3helpful
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
1helpful
Scansoft paperport 10 keeps loading every time i switch on
Check the Startup folder in the Start menu. If it is there, simply delete the entry there. Otherwise you can use "msconfig" from the Start Run menu to control the startup programs and disable paperport.
Nuance PaperPort 12 Logo
Top Nuance Computers & Internet Experts
 Grubhead
Grubhead
Les Morrison
Les Morrison
ray gallant
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
