Samsung CLP325 Laser Printer Logo
Posted on Jun 04, 2011
FUSER UNIT FAILURE - Samsung CLP325 Laser Printer
1helpful
Printer fuser failure
replace the fuser. Fusers have a life span based on the number of prints and not the age.
If you dont print alot on the unit, consider contacting the retail store or manufacturer
2answers
Fuser unit failure #U1-2320
The Samsung printer error code u1-2320 is related to fuser that means the fuser unit fails. Need not to worry; this error can be encountered by many Samsung printer users. ... The Samsung printer error code u1-2320 is also the fuser error; this might be resolved just simply power off the printer.3
0500H Fatal Error
Witam,
0500H Heating roller warm-up failure:
The thermistor /1 does not detect the specified temperature and the warm-up cycle is not completed even after the lapse of a given period of time after the cycle has been started.
Relevant electrical parts
Fuser unit
Printer control board (PRCB)
DC power supply (DCPU)
Solutions:
1 Check the fuser unit for correct installation (whether it is secured in position).
2 Check the connector between fuser unit - PRCB PJ9 for proper connection and correct as necessary.
3 Check the connector between fuser unit - DCPU CN2 for proper connection and correct as necessary.
4 Change fuser unit.
5 Change PRCB.
6 Change DCPU.
1helpful
5answers
Printer prints out but all powdery and wipes of page .
I agree the fault is almost cetainly with the fuser unit.
4helpful
2answers
It displays c50 minolta cspro 1030
That error code means that the you have a problem with the fuser unit. You are going to have to replace the upper fuser roller. The fuser roller and the heating unit is all one unit and is known for arching out. Good Luck in finding one.
AL1610 code h4
This problem is fuser (the section that gets hot) related. It could be one or more of the following things :
Thermistor failure
Heater lamp failure
MCU PWB failure
Thermostat failure
Power supply failure
Interlock (door) switch failure
It could be that the thermistors(monitoring temperature) are just dirty and need cleaning or the thermostat has blown. THe heater lamp inside the fuser roller may have stopped working or their is a power supply issue to the fuser.
You could try pulling the fuser unit out of the copier and checking it / clean it. With these models its usually easier and cheaper to buy a whole new fuser unit.
You could try resetting the fuser error code in service mode.
To enter the service mode press the following keys
Clear (then) Density select (then) Clear (then) Density select (while in this mode do not adjust anything else as this could further damage your system)
enter "14" (with the copy quantity keys) and press copy key. Now restart the copier.
No fusing at all. fuser cam stuck in open position
Probably a faulty Fuser. Try replacing the Fuser and see what happens.
Did the Fuser Upper Failure magically disappear? If it did, and you just kept on printing thinking it just "went away".... try a new fuser.
Brother HL-5270DN printer says ERROR E50
Brother error e50
The error code E50 indicates a fuser unit failure - the fuser unit is no longer working and needs replacing. The error may also display itself on your Brother printer's front display panel as "Fuser Unit Failure" or "Replace Fuser Unit."
What Does the Brother Printer Code E50 Mean? - Small ...
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
