Question about Galaxy Radios DX-959 40-Channels Base CB Radio
I want to know the correct method on how to do a SWR test with the Galaxy 959.I have a 5 foot self adjustable firestik and have mounted it to a 4mm thick aluminum plate 30 cm square and will have it higher than the tin roofs around me.It seems that on the face of it the radio has a built in SWR mater,but I don,t know if that can be relied upon.Which way do you know is the best way to SWR this type of 27 MHz radio,and Thanks for any Help.
Posted by vindication on
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
The best way is with an antenna analyzer but that is too expensive unless you do SWRs for a living. The meter on the radio should suffice for your needs.
Adjust the screw on the antenna until it is about 1/2 inch out.
Place the srf/swr switch to swr.
Go to channel 1 and note the SWR reading on the meter.
Go to channel 40 and do the same.
If channel 1 SWR is higher than channel 40, then screw the tuning screw out a turn or 2.
If channel 40 SWR is higher than channel 1, then screw the tuning screw in a turn or 2.
Repeat until the SWR on channel 1 is the same as 40. Channel 19 will be the lowest.
If you are not comfortable using the built in SWR meter, you will have to invest around $20 for a small SWR meter.
,,,,Don at NTCB, Inc.
Posted on Jun 29, 2011
Swr light come on when i key it up
you must check your radio for low SWR.get it down below 2.1 and you should be ok.if you already have a low SWR then you may want to take it to a tech and let them fine tune it.
Apr 02, 2014 | Galaxy Radios DX 959 SSB CB Radio
Why does the sound come back on when I press the mic on my galaxy 959
bad ground to antenna Check your SWR with a voltmeter and a swr meter.check everything, check your mic connection for broken wires try another mic.
Aug 01, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
Cobra 148 GTL, Firestik II 2' tunable tip, Firestik K 74 lip trunk mount. I can't get a good match. SWR is in the red.
did you try sand paper. where the mount meets the metal you should sand off the paint to get a good ground. If that doesn't work try a longer antenna.
Jan 30, 2013 | Firestik K-74 Trunk Lip Antenna Mount
RED SWR ALERT LIGHT COMES ON WHEN I KEY UP
In most cases if the mic works the common cause is the transmitter in the mother board is shorting out or not soldered to the board properly. another cause could be that your antenna is too close to the CB and will disrupt the signal.
Oct 14, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Self adjusting SWR does not work on 959 Galaxy
the swr on the radio is not what you are thinking it is. You have to set the SWR to anything below a 2.0 and the meter will let you know when and if your swr gets to high.
Sep 23, 2012 | Galaxy Radios DX-959 CB Mob Auto Swr...
Galaxy DX 959. SSB doesn't seem to work. The power meter needle moves in AM but not in SSB. I tried adjusting the bias between test points 7 & 9 to 50 mA via VR12, but can only get it down to 90...
on ssyou are some what familiar with working on radio's. just make sure before you pull your hair out aligning the radio that you made sure it definitely is not tx on ssb. b the.Mic gain will increase the modulation. it could just be a meter issue. confirm this by having some one on another radio on ssb the same channel listen for you. if he cannot hear you then the ssb is blown out.sounds likelike
Jun 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Can't talk about 2 miles ,swr is good
If your talking at least 2 then it sounds like it is the antenna. Any antenna should talk 10-12 miles on a good day, no matter what radio you're using. So I'd get a second look at that system.
May 30, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy 959 distant stations sound like they are on sideband
jsmith? as in jaden smith or some other looser named j smith?
Jun 20, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
111 people viewed this question
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
