Please download the file amcap920.zip from http://www.download25.com/install/amcap.html and install the setup.exe. It will create "amcap" in programs. click the amcap. you can see the video from cam.
If you satisfy with my solution please rate/vote for me. Rating/Voting will encourage me to help othershI zlewoll, can you able to open the webcam now?
You can't post conmments that contain an email address.
hi,
please check the mechanism side, if you left your cam for a long period with cassette loaded position, the tape will stick on the head and roller of you cam, if so you have to manually loosen the cassette reel from.
To transfer your video to your pc please do the following:
1. Make sure that you have installed the software that came with your camera. If not insert the supplied cd in your dvd drive. When the dialog box appears select Easy Installation and follow the instructions.
2. Close your camera's LCD monitor.
3. Connect the usb connector to the camera and the pc.
4. Open the LCD monitor and from the menu select Backup.
5. Click all volume and click Next and then Start.
You're video cam has a name and model number on it or within its manual. Go to the manufactures web site and download the web cams driver software. Once completed just plug the web cam into an open USB port. Windows will see the cam and ask for the software drivers.
Run the software from the manufacture.
You need to use 4 pin Firewire cable to connect to your PC.
Drivers may be auto installed. Else, you can install from the CD which came with the cam.
After connecting the cable, switch on the cam and open movie maker to download the video.
be sure that you installed the cd driver camed with your camcorder and also try using ULEAD MOVIE MAKER as im using now with my camcorder. its very easy to use. hope that helps!
