Question about GE Refrigerators
I have a GE Adora side-by-side refrigerator Model # DSD26DHWA-BG. About 1 year ago the ice maker stopped producing ice. The mold that forms the ice cubes is filling up with water but never pushes out cubes. The water dispenser works fine. I also noticed over the last year that on occasion when I would open the freezer there is ice crystals all over everything and its getting worse. Sometimes when I open the freezer door I would notice that all the ice crystals have melted then the next day they have formed again. I read on the GE website that if you have little or no food in the freezer this can cause air circulation problems. Granted we hardly have anything in the freezer at one given time maybe 2-3 things but I feel thats not the issue. I tried the ice maker diagnostic reset that GE recommends but no change. I'm handy around the house so I feel confident that if it needs a replacement part I can replace it with instruction. Thank you so much for your time!! Please help! Jarrad Cody
Posted by Jarrad Cody on
Rick Ead
  • 1,998 Answers
Hello, there are three screws that hold the icemaker in place if you remove these three screws and unplug the icemaker and remove it from the unit. After you take the icemaker out take the entire unit with the cover on it and run it under hot hot water this is actually quiet common for an icemaker to freeze up well actually its the parts on the inside of the icemaker that are freezeing up. After you defrost the icemaker as I term it then you would dry the icemaker and reinstall it. when the icemaker reaches 32 degrees the icemaker will call for water once again from the water valve if at this time after the ice forms the unit still doesnt drop the icecubes then you would have no other alternative then to buy another icemaker they usually sell for around 50-90 dollars american. The icemaker is not worth replacing parts on due to if you were to replace parts on the icemaker you would end up spending about 4 times as much as the entire icemaker costs. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again Rick
Posted on Jun 04, 2011
  • Jarrad Cody Jun 04, 2011
    Thank you for the info, I will look into that. I don't think that would cause the ice crystals on the walls and shelves. Do you?
GE adora side by side French door ice maker keeps freezing up and led light blinks. Have had repairman several times for same problem. Can I removed unit to thaw?
  • Possible solenoid fill valve failure
  • Possible failure of the mold heater, not allowing the ice to be removed from the mold.
  • Possible failure of the mold heater thermostat
Aug 30, 2014 | GE Adora (DSF25KGTBG) Side by Side...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Kenmore Coldspot Side by Side Model #57562791
hi debie normaly the life of these ice maker range from 3 to 4 years then the wtr hardness eats them up and the mold start leaking wtr but if is a fairly new model the you have a faulty wtr vale that is not closing sending wtr all the time to the ice maker repl the ice maker is you see is peeling of the texture inside if it is ok repl the valve
Oct 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint Ice Maker Stopped Making Ice
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
446 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Arsim Shabani
Level 1 Expert
