Maytag Neptune MDG5500AW Gas Dryer Logo
Question about Maytag Neptune MDG5500AW Gas Dryer
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
Posted by Joseph Elkayam on
Anonymous
    Scholar:
    New Friend:
  • 113 Answers
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Posted on Jun 04, 2011
2answers
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected]
Our Whirlpool gas dryer, Model # LDI5701W1 stopped working in the middle of a cycle. Power supply is fine. With door closed, I can't hear the timer humming. Could it be a door switch, timer,?
it maybe but here is a website that shows how to test them, it may be a loose or broken wire, a reset button on the motor, or other things:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
3helpful
2answers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 • Dryers
4helpful
DRYER WONT START
HELLO THERE:
The most common problems with this problem is that there is a fuse that has blown in the dryer or that the door switch has failed and needs to be replaced or the timer switvch or the motor it'sef has went out (NOT LIKLEY) THOUGH
Or THE dryers push start button is faulty
so please check these things out and replace any parts that are found to be defective
Hope this is very helpful for you best regards Mike
Hi,Dryer wont restart
def. sounds like a bad or failing motor situation... motors cost anywhere from 125 to 200 dolloars... not too hard to replace though....
1helpful
3answers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
1helpful
Power button wont start dryer
check the door switch,also you can remove the back panel and check the little white main fuse on the blower box-mike
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Top Maytag Dryers Experts
Marvin
Marvin
David Shaub
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
