SOURCE: no water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
SOURCE: how to remove the cartridge from my pegasus
remove handle , unthread collar , same with chrome body base . make sure water is turned off from valve
