JVC LT37XM48 LCD TV Logo
Posted on Jun 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Video problem. Lower 3/4 of screen flickers off and on with a "blacker than normal" screen. Works well for a few minutes, then black shading occurs off and on. Within black shaded area, screen image freezes momentarily.
Anonymous
Level 2:
Sergeant:
  • Expert 302 Answers
  • Posted on Jun 04, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
302
Questions
0
Helped
91739
Points
594
Your screen is defective. Screens are very expensive to replace but you might be able to find a used one on line. You will need the part number of teh screen it is located on the back of the LCD panel on a white sticker. Do a google search and see if anyone is selling it. You can try www.interliquidparts.com
UNSCRAMBLE THESE LETTERS TO MAKE 3 WORDS
Did you mean 3 words which make sense together? How about 'rocket lab pilot'
If they don't have to make sense together there are many possibilites
A Bitter Pollock
A Brooklet Clipt
A Blotto Prickle
Cab Kite Trollop
Cab Tike Trollop
Cab Triplet Look
Cab Plotter Kilo
Crablike Lop Tot
Crablike Pol Tot
Crablike Plot To
Crablike Lot Top
Crablike Lot Opt
Crablike Lot Pot
Tieback Poll Tor
Tieback Poll Rot
Tieback Poll Ort
Tieback Roll Top
Tieback Roll Opt
Tieback Roll Pot
Tieback Troll Op
Tieback Toll Pro
Balletic Pork To
Blacker Pilot To
Blacker Toil Top
Blacker Toil Opt
Blacker Toil Pot
Blacker Lip Toot
Blacker Pi Lotto
Blacker Pit Tool
Blacker Pit Loot
Blacker Tip Tool
Blacker Tip Loot
Backer Pill Toot
Backer Pilot Lot
Backer Toil Plot
Backer Lip Lotto
Backer Tilt Loop
Backer Tilt Polo
Backer Tilt Pool
Bracket Pill Too
Bracket Oil Plot
Bracket Pilot Lo
Bracket Toil Lop
Bracket Toil Pol
Bracket Lip Tool
Bracket Lip Loot
Bracket Lit Loop
Bracket Lit Polo
Bracket Lit Pool
Bracket Poi Toll
Cable Kilt Troop
Placebo Ilk Tort
Placebo Ilk Trot
Placebo Kilt Tor
Placebo Kilt Rot
Placebo Kilt Ort
Back Little Poor
Back Politer Lot
Back Loiter Plot
Back Toiler Plot
Back Peril Lotto
Back Triple Tool
Back Triple Loot
Back Litter Loop
Back Litter Polo
Back Litter Pool
Back Tiptoe Roll
Back Tie Trollop
Back Rootlet Lip
Back Petrol Toil
Back Plotter Oil
Back Tooter Pill
Black Politer To
Black Polite Tor
etc etc
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
I have a Vizio VF550XVT1A. First problem was a flickering screen that ended with the TV turning off. I replaced both invertor boards and the TV seemed to work fine for a few weeks. Now the TV works fine...
Good day sir Alfred!!!!
If your screen turns to back after a minutes but the sounds is normal..That problem is very common to all flat panel specially to LCD TV..
OK,I need to know first if your TV having a back-light when the picture went out after a minutes.If that so the possible problem is T-CON board (this board is the responsible to produce a video on all LCD TV)..
If you don't have back-light the problem is inverter board again..But before you order or install new inverter board try to find why the inverter board gone only on few weeks after you install it..the possible problem why the inverter board faulty for the short period of time is higher/lower input voltages (24vdc) comes from power supply..try to check it using volt meter or multimeter tester..it should be read 24vdc on meter..let me know if the voltage drop or higher to 24..
If the 24vdc is fine the only problem is the condition of inverter board maybe its used or partially faulty when you buy it..
if you have more queries and clarification regarding my solution please feel free to reply on this tread...
Hope it helps..
Thanks for using fixya..
5helpful
Bottom half of screen black-out
I would replace the lower Y buffer. Part number 996500032640. Goodluck.
2answers
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
My screens works for about 10 or 15 minutes and then goes out...
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
2helpful
Screen goes black when plugged in
The high pitch sound is most likely a faulty inverter. Most defective screen are caused by a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
1helpful
My Screen goes black fter a few minutes
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
