Posted on Jun 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to download cannon printer software i455 and install it in my computer
Anonymous
Level 3:
Guru:
  • Master 352 Answers
  • Posted on Jun 04, 2011
Anonymous
Master
Level 3:
Guru:
Answers
352
Questions
0
Helped
98076
Points
1095
Hello.
The Driver is available from the link below. it is a free download.
For Windows XP - CLICK HERE
For Windows Vista - CLICK HERE
If this helps please rate my answer. Thank You for supporting the FixYa Community
Regards
GM
I cannot get my cannon to scan a photograph from printer to computer - please help before I push it off desk.... thanks
First - verify that you have installed the printers software on your computer before connecting it to your pc? If you have not installed the printers software, or do not have the disk to do so - go to Cannons website and download it to your pc. www.cannon.com. Click on support, then find download drivers/software and enter your make and model of your printer. Follow the prompts to download and then install it.
How do you know if you have or do not have the software already installed? You should be able to find the cannon software for your printer on your desktop. look for the icon.
Once you have the software installed, there are two ways to scan something to your computer.
You can scan from the printer to the pc. Or you can scan from the pc to the printer. What does that mean? It means you can use the printers keypad and send the image to the pc. Or you can open the software in the computer and request the image from the printer. You either send or request but the end result is the same.
The easiest way is to use the software in the computer. Double click on the cannon software on your desktop. Find the "scan" option and click on it. Make sure your printer is turned on and connect and click "ok" to start the scan. The picture will appear on your screen. You can adjust it when its finished.
If you want to try and scan using the keyboard on the printer. press the scan button. The printers display will say "searching for applications" and there will be a delay until it is finished. The printer is searching for compatible applications to send the image to. The choices are usually microsoft word, Adobe pdf, internet explorer followed by any graphic or image software you have installed that the printer recognizes and the cannons default software. When its done downloading the applications, you have the ability to choose which one you want to send your image to. Press the "send to and pick the application you want to use" on the printers display. Then press "enter" or "ok" and the image will be sent to that program and appear on your computer screen.
2answers
I've lost the installation disc. Can I get this
You can download the required drivers and software from manufacturer's site by clicking this link
On the page which opens, select your operating system to download the appropriate drivers and software.
Hope this solves your problem. Thanks.
1helpful
Need for Cannon Digital Copier & Printer ir2016j driver
Try www.canon.com. They should have the drivers/software for you in the support area available for free download. Hope this helps & please take a moment to rate this solution. Thanks.
Lost installation disk for my cannon copier
check available drivers in your computer,select the cannon model you have or any other compatible cannon model.if no success download from the internet,www.digipro.co.uk/products/photocopier-software/a3-copier-black-white-drivers/
I need to delete the software for a Cannon MP30 printer from my computer. I have Windows XP Home and the regular Microsoft program for removing it does not get the job done. I can not find the installation...
to remove your software go to >> Start >> Control panel >> Add/remove programs
If you did it already and your software is still in your computer do this:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation. (usually in folder "Program Files")
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
To get your software go to: www.canon.com
Support >> Sotware and drivers
And download form there your printer software
I HAVE A CANNON C5000 AND CANT REPROGRAM IT TO MY NEW COMPUTER
Try this:
Create a new folder on your desktop and name it newprintdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
1helpful
2answers
Software for pixma iP 1700 printer
please help where to download driver for pixma iP1700 i needed badly
Top Cannon Office Equipment & Supplies Experts
NOEL
NOEL
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
