Http://support.microsoft.com/kb/926993
It's a fatal error and they want to fix it.
If you want to try to fix it (when you do things like this you can mess up and brick your zune but if you follow directions you should be fine) enter recovery mode and restore from scratch. You will lose everything on the zune including firmware but it will restore from the computer and should work regardless of what the issue is. When it restores it will reinstall your firmware apps music anything synced. It is a very common fix on iphones (called dfu mode). I would need the model of your zune to tell you specific instructions but look up how to enter recovery mode (or how to reset) for zune in youtube with your model and it should have someone showing you how. Good Luck!
