Question about NorStar M7310 Corded Phone
I have the norstar m7310 I would like to know how can I see what extensions are in use??
Posted by mztai_07 on
Carl Navarro
  • NorStar Master
  • 2,460 Answers
5 Related Answers
Anonymous
SOURCE: Norstar M7310 auto attendant problem
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
Posted on Mar 16, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: how can i change my extension nuber (norstar M7310)
Sorry can you clairify this question...
-> You need a new extension number for your set?
-> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press:
- Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite,
- then RLS,
- press FEATURE * 2
- press the button where you want to add this new extension
- dial the extension of the new person
Voila you are done!
Posted on Jun 03, 2009
consultel1
george peters
  • 860 Answers
SOURCE: Change extension to another line pool
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the show key (top right arrow)
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key till you get to the desired pool(bottom right arrow) .
Press the Chng soft key from N to Y
Press the heading key till the display says Line Pool Access(top left arrow).
The display should say Prime Line
Press the Chng soft key till you get to the desired pool
Press the release key when finished
Posted on Oct 01, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do we remove an extension from a hunt group in
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool2.gif on.
Press the next key 6 times (bottom right arrow) .
The display should say System Prgrming.
The display should say Hunt groups
The display should say Show Group:
Enter in the group number of the member that you wish to delete.
The display should say Member DNs:
The display should show members for that group.
Scroll to the member you wish to delete.
Press the Remove soft key.
Press the heading key(top Left arrow) till the display says Show Group: again.
Enter in the group number you wish to to change the deleted member to
The display should list the current members of that list
press the Add soft key.
enter in the DN of the member you wish to add
Select Appr & Ring setting for the hunt group member
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Norstar/Meridian M7310
On that phone, without picking up the handset, press FEATURE *7 and dial a number from 0-7. (higher numbers darken). You may also have a soft key that has the UP DN legend.
Posted on Apr 05, 2010
"Set unavailable" error received when I tried to Set Copy on Norstar M7310 phone
Are you sure you have the correct extension number for the destination? I may be more than "not progammed correctly" - perhaps it isn't the ext# you think it is. Try Feature*0 then all the keys, especially the line keys, which should give you the extension number.
Apr 21, 2015 | NorStar M7310 Corded Phone
I have put a main greeting on my Norstar M7310 phone for all 5 incoming lines, however one of our incoming lines has grabbed a personal message form another extension and callers get that personal message...
You need to know what extension is causing the forward directly to voice mail. Chances are that this extension has ringing lines programmed to it and the forward on busy is to voice mail. ANY PHONE THAT HAS RINGING LINES SHOULD NOT BE SET TO FORWARD ON BUSY. If they happen to be on the phone when a call comes in it will go straight to their personal mailbox.
Aug 09, 2013 | NorStar M7310 Phone
Norstar M7310 getting Not In Service message
This message means that the system does not see a telephone connected to that extension. Check the extension that you are calling to see if it is operational. Check the extension number by using Feature *0 and pressing the intercom button.
Apr 05, 2013 | NorStar Meridian M7310 Phone
Nortel Norstar T7316 programming extention to button. Won't let me program extension 230.
Just think about it, why would you want to auto dial yourself? You don't need an autodial key for yourself so the system don't allow you to program it.
Sep 25, 2017 | NorStar Meridian M7310 Phone
Incoming calls on Line 4 are ringing in personal office and mail line. I want it only to ring on Mail line . Our phone is a Norstar M7310. Thanks Sherrie
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
May 20, 2011 | NorStar M7310 Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
How can i change my extension nuber (norstar M7310)
- then RLS,
- press FEATURE * 2
Voila you are done!
Jun 03, 2009 | NorStar Meridian M7310 Phone
What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
Mar 23, 2009 | NorStar Meridian M7310 Phone
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
NorStar M7310 Corded Phone Logo
112 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
