SOURCE: i have a 125l trimmer and it runs for about 10
I had the same problem. Check the fuel line right above the grommet on the tank. Mine dry rotted and had a small hole in it sucking air. The trimmer would start ok but wouldn't run long or at all wide open. Replace the fuel line and grommet (all one piece).This fixed my problem.
SOURCE: Husqvarna 323L gas trimmer runs & starts great
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
SOURCE: I have a husqvarna 125L gas trimmer and dies after
Could be clogged gas cap. Take the cap off and see if you can blow air through it. If no air passes, the trimmer will become vapor locked and wont be able to get enough gas.
SOURCE: Engine Seized after running trimmer for 5 min w/ no mix
ryobi trimmer was "parked" for 4 years, now it has no spark. ????
