Question about Eiki LC NB2UW Multimedia Projector
MY EIKI LC-NB2UW Projector have "ghost image" or
  • Angel
    Angel Jun 03, 2011
    What is the length of your VGA cable? Are you using a booster or an amplifier for signal?
    Too much signal input can cause ghosting.
  • mickeyalexis Jun 04, 2011
    THANKS ANGEL!: I JUST HAVE A DVD PLAYER PLUGGED WITH RCA CABLES,, BUT EVEN IN THE MENU (ANYTHING PLUGGED IN) STILL DOING THE SAME.
4 Suggested Answers
6ya staff
SOURCE:
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: Display color problem, Eiki projector LC-NB2UW
Hi sjmuseum
If you cannot find the advanced option in the standard users menu , then it will only be in the Service Menu which you would have to call Eiki support to find out how to enter the Service Menu.
Posted on May 14, 2008
Anonymous
SOURCE: Shuts off after using it for a while....Eiki LC-NB2UW
I have the exact problem. I have been using a portable fan next to the projector to keep it cooler it allows me to use the projector for work. I know that this is not the "fix" but it helps. If someone has the solution, I would like to fix the projector.
Posted on Mar 04, 2009
Anonymous
SOURCE: In reference to the Eiki LC X999 projector
I figured it out by opening the bottom. The lamp was easy to change.
Posted on Feb 01, 2010
Projector lens in focus yet the image isn't sharp and the fine lines have Halation around the edges
How long is the cable run? If it's too far away then that's what's causing the "ghosting" effect. You'll need some sort of transmitter/receiver. To quick troubleshoot, bypass the long cable run, and use a shorter cable to connect to the projector and see if the issue still shows.
Jun 27, 2015 | Eiki LC-X800A LCD Projector
Eiki lc x1100 multimedia projector lyrics are "shadowed" with multicolors
screen ,the color is ghost,
LCD panel is broken.you need a new one USD120
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 19, 2013 | Eiki LC-X1100 Multimedia Projector
Eiki LC-XC1 color problems
check all the optical parts around the blue lcd-panel, they might be darkened due to heat
May 07, 2012 | Eiki Office Equipment & Supplies
DOUBLE IMAGE TO THE LEFT EIKI LC-XGA971
broken lcd panels, timing incorrect. very costly to solve
Sep 08, 2011 | Eiki LCXGA971 LCD Projector
I have an eiki xbl20 projector that i mounted upside down. How do I get the image to turn right side up?
Nov 20, 2009 | Eiki LC-XB15 Multimedia Projector
Sep 21, 2008 | Eiki LC NB2UW Multimedia Projector
Hi sjmuseum
May 12, 2008 | Eiki LC NB2UW Multimedia Projector
Colors displayed
Go to Menu, Advanced, and set the color adjustments to RGB. That should work.
Dec 03, 2007 | Eiki LC NB2UW Multimedia Projector
LC-NB2UW on/off problem
does the remote control works for other functions ?? if no try to make factory reset setting through out settings menu
Apr 30, 2007 | Eiki LC NB2UW Multimedia Projector
Eiki LC NB2UW Multimedia Projector Logo
89 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
paul vail
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
