Washing Machines Logo
Question about Maytag Washing Machines
How do i change the run time on the quick wash
Posted by gmhyer on
tallboy57
  • 51 Answers
Most run times are at factory settings, an cant be changed, the quick wash , is a quick one.
Posted on Jun 03, 2011
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
How do you adjust length of washing programme.
Change the wash settings and the cycle time will change along with the options. Most machines have a 'quick cycle' to shorten wash time, or you can choose "heavy" and "pre-wash" to make an extra long cycle... Depends on the model.
Washing white clothes washing in machine become dull very quickly... even if white clothes are washed separately...Any clues to improve that?.....
Give the machine a good clean out. Run a cycle with the addition of white vinegar, and then change your washing powder or liquid. You can also add a booster product to the wash cycle.
My neptune front loader " cycles" the timing is messed up. I have "quick wash" which normally runs for 38 minutes. Since power surge, my "quick wash" now runs for 51 minutes. I've unplugged in hopes it...
Have you tried unplugging it for 1 hour? Yup surprisingly
that is one of the answers for clearing out fault codes on this machine. Sure hope that it works even though you don't have a code a full hard reset may do it.
Best to you.
Whirlpool washer duet sport ht MOD # WFW8300SW02
did you try to diconnect it from wall?
try to disconnect it.... wait for 5 minutes and try to connect it again and try if same problem still occurs....
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 • Dishwashers
7helpful
2answers
Mdb6650aww code flash: Rinse Cycle & Wash Button.unit inoperative
You might try running the diagnostic mode which can be model dependent. To find your particular method to do this .... unscrew and remove the lower kick plate under the door. The service technician paperwork is usually taped to the kick panel or the tub or side wall. Within that paperwork should be the work process to run through the diagnostic mode. The work process is one of pushing various control buttons in a sequence within a quick time frame and repeating 2-3 times.
If that fails ... other potential reasons run the gambit of a bad control panel (or loose wire connection to the panel), bad heating element, etc
Good luck on your troubleshooting!
Jan 20, 2018 • Dishwashers
Will run at rough at idle but won't take any fuel
This isn't a 100% solution, but a saw only runs as clean as the air filter, and they get dirty quick. I give my air filters a quick wash about 5-7 times with just soap / water.
If that doesn't do the trick, your probably looking at some kind of carburetor issue.
Top Maytag Washing Machines Experts
Robert
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
