Question about Health & Beauty
Freerider Ascot Electric Mobility Scooter (4 wheel) Battery charges and holds current - horn works and shows green on power dial Scooter hardly moves underload - the engaged lever is set correctly. I suspect a motor issue but i am unsure. any advice would be greatly appreciated Many thanks in advance
Posted by katmoda on
lennieg2000
  • 692 Answers
I would suspect the brake is not releasing correctly and dragging on the motor housing. Try driving the scooter a short distance and feel the motor case at the rear near the brake assembly if it is very warm or hot the the brake is sticking and will have to be replaced. Hope this helps
Posted on Jun 04, 2011
My leo mobility scooter charger light shows green as soon as connected to power it remains green when attached to the battery and does not charge
Hi, that could be because it can't see the battery voltage in most cases or at worse the batteries refused to charge, or your charger has called it a day , check the fuse on the scooter as well...
Regards
www.gewizrepairs.co.uk
Oct 06, 2013 | Electric Mobility 4 Wheel Power Electric...
How many miles can I get from a fully charged Freerider Ascot 4 mobility scooter? My scooter seems to run out of charge after a few miles.
11 miles on full charged new batteries, this is approximately as condition change max distance, like you weight, if you are going uphill, how even the ground is etc. if you need more you could get a spare battery pack for it, and swap them over when needed. but remember to keep them charged even when not in use once a week is the best way to keep them in good shape.
Sep 09, 2013 | Health & Beauty
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
What does it mean when the green light which comes on with the ignition flashes please? I have a Mayfair economy scooter but it is second hand and I have no user manual with it. The battery shows 3/4...
I AM A TECH FOR ELECTRIC MOBILITY # 1-800-MOBILITY
THE FLASHING LIGHT USUALLY MEANS LOW VOLTAGE AND THE BATTERIES ARE TOO LOW TO RUN THE SCOOTER. REPLACE THEM.
GOOD LUCK
TIM
Apr 29, 2011 | Electric Mobility 4 Wheel Power Electric...
Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Jun 22, 2010 | Electric Strider Maxi 4 Wheel Mobility...
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Health & Beauty Logo
362 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
