My Bosch logixx8 machine is in child lock and i can not return it back to normal
Andrew Calhoun
    Novelist:
  • 182 Answers
Press and hold the start button until the child lock turns off.
Posted on Jun 03, 2011
How do I reset my bosh logixx8 washing machine WAS24466GB/5
Hi
Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 second
Sep 26, 2014 | Washing Machines
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
Washer LG wd80264tp showing on dislay CL and not starting
Hello there and welcome to fixya
This is a very common error code this stands for child lock
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock. you may have to hold them down for a min of 3 sec and you should see it return back to normal
You can also unplug the machine for 1 hour to allow for the internal reset feature to reset the memory module ok
Hope this helps
Best regards Mike
Aug 08, 2011 | LG Washing Machines
How i unlock a bosch classicxx washing machine possible child lock.
press and hold the start/pause button for about 5 seconds then it should take the child lock of and should be back to normal operation.
Let me know if that doesn't work for further directions.
Good luck.
Jun 29, 2011 | Washing Machines
I have error message nr0 on my Bosch LogiXX8 What is wrong and how to mend?
It is the child lock. Turn machine on & then press & hold the start button for 5 second. Code will flash then disappear & machine will be back to normal.
Page 5 of instruction manual for more details
Oct 18, 2010 | Washing Machines
Cant disable child lock
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Apr 21, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
351 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
