Error Code SY EF is the System Evaporator Fault.
This usually means there is NOT enough air flow over the sensor,
this can mean a faulty sensor, or fan. Above is the latest service sheet to do with your machine, you need to check this.
Hope this helps (remember to rate and commnent this)..
Additionally, in this link could find Owners Manual for Frigidaire Gallery Series Stainless Steel 26 Cu Ft Refrigerator
Good luck.
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
