SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
SOURCE: Garage door opener won't work
you should have installed a emergency key release !, it,s a cylinder that you put a key into and pull out a cable thats attached to your emergency release inside the garage , right now you would have been in already , but since you never installed one lets deal with the problem at hand , answer me this : do you have power inside the garage ,are you certain that the breaker is on ,did you have any recent power failures ?, because the circuit board on your machine could be fried from a close lightning stike , and i,ve seen it a thousand times , also your capacitor on your machine may be shot ! is your door wood or steel? if its wood drill out a 3 inch hole saw hole on the top panel either to the left or right of the center wooden cross member , now get a flashlight and look for a emergency relese rope , after you have located it,make yourself a coathanger with a hook at the end ,tug at the rope until your able to pull at the handle thats attached to the rope once you are able to release the door from the carriage assembly keep pressure on the handle and have someone else lift the door and when you want to fix the hole you made just simply glue the circle cutout back in place , good luck and do what i say to get in , please leave a nice rating if i was able to help you ,sincerely glenn
