Question about Dryers
Brown burn spots on Whites
I have a GE Dryer ~2001 Model DVL 223 EAOWW and on occasion I will find a brown burn like spot on white articles of clothes, shirts , dresses etc, I thought makeup, dye bleed in the laundry basket or something, as it first appeared within the first 6mo-1 year I couldn't understand how the dryer can make those marks as I cleaned filters and inspected for rust inside the drum but yet another damaged dress of my wifes yesterday has convinced me something is happening. All I ask is why??? Everything sounds a seems to run fine...HELP..Thanks
Posted by jeffbucknam4 on
robert
  • Dryers Master
  • 2,534 Answers
I would guess lint is being burned in the heating element and then being blown onto clothes. Visually check the vent holes in the back top of the inside back wall for burned look.
Posted on May 06, 2017
Greg P
    Master:
  • 538 Answers
Hot spots in the drum perhaps. Check for a loose heating element.
3 Related Answers
Paulo
  • 188 Answers
SOURCE: Dryer leaves brown spots on clothing articles.
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Posted on Mar 23, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Posted on Jul 20, 2009
Patrick Rayome
  • 1757 Answers
SOURCE: Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Posted on Nov 10, 2009
My dryer is getting a hold of articles of clothing right inside of the door (near the light) and when it does it is burning a hole into the clothes. There was a sharp piece of plastic sticking out in this...
Your glides is worn out and probably the bearing too. Easy fix:
themobilian_2346.jpgyour model number is to the right of the screwdriver in the first photo, These GEs use different parts per production run.
If yours is bad as i think it is you gonna have to replace the glides and the bearing they mount to.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2011 | GE DBSR453EBWW Electric Dryer
The top of the dryer gets hot when temp control is not set on off
One of your heating elements has broken and welded itself to the heater housing. When the timer is activated L-2 powers the remnant through the timer to the neutral. You need to unplug the dryer and fix the heater element. 9b8cf19.jpgbc36f64.jpg97143cb.jpg
Jul 26, 2010 | GE DVL223EBWW Electric Dryer
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
We have had this dryer for 6 years and for the last year it has been leaving brown marks on our clothes. The brown streaks will not come out easily. We have cleaned the dryer on the inside but this has not...
This is usually from the clothes being pinched. Either in the front or rear. The front uses a glide type system on GE style dryers and felt and rollers on most others. Here is a link. Check the type of dryer you have or send me the model # and I will direct you, then follow the links in the troubleshooting to the video that fits your dryer. If you enter your model # you can also get diagrams and illustrations that will also show you what type of dryer. The repairs are easy to do and inexpensive.
http://appliancehelponline.com/edryerburnmarks.html
Jun 15, 2010 | Dryers
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Brown spots on clean white clothes
The drum seal is bad in your dryer. Those brown spots are burn marks. It's actually burning your clothes. Unfortunately this is not an easy fix. The same thing happened to my wife and I. I can fix many things, but I decided this wasn't worth fixing since I'd have to take apart the whole dryer to fix it. It would've been very time consuming and you'd have to have the technical ability to tackle the job. We just bought a new dryer.
Jul 12, 2009 | Amana DLE330RAW Electric Dryer
Dryer leaves brown spots on clothing articles. Suspect back seals as gaps are evident and drum is loose within the unit. What is remedy? Cost of seal replacement?? Kenmore 62802 Electric Dryer Deb in Brown...
Mar 23, 2009 | Kenmore Dryers
Dryer leaves pinkish-brown residue stains/streaks on white clothes
The cause of these stains is worn seals. Over the course of time debris & chemical residues left from the wash process are deposited into the drum seals. The continual heat applied to these residues causes a reaction which turns the seals a reddish brown in most cases. The time this takes varies with the amount of laundry done. Clothing is then brought into contact as they tumble in the dryer. To remedy the problem you will have to replace the seals on the drum.
Each manufacturer has different designs so what is involved is determinant on the manufacturer. The most common domestic manufacturers are Whirlpool, GE, Frigidaire. Most of the brand names seen in stores are derivatives of these. This includes Maytag. It was purchased by Whirlpool in 2006 who has been incorporating their design into Maytag since. Only the Maytags since 2006 have the Whirlpool design. In 2006 they were still selling the old Maytag stock while retooling to manufacture the Whirpool design so you have to tread carefully when determing what you have if purchased in 2006 & possibly into early 2007.
Whirlpool--Some other derivatives--Roper, Kitchenaid, Estate, Kenmore.
Frigidaire--Westinghouse, White-Westinghouse, Gibson, Kelvinator, Tappan, Magic Chef, Electrolux
GE--Hotpoint. GE also manufactrurs some appliances by using off-the-shelf designs. As an example some of their dryers use a GE--Frigidaire derivative.
This is not meant to be a comprehensive list. It is also not meant to say they are all equal as long as you buy any brand from that particular manufacturer. The reason for having so many different brands is that while you incorporate some basics of design similarity you can also add or subtract features to have a particular brand serve a niche in the marketing scheme.
Feb 20, 2008 | Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
125 people viewed this question
Top Dryers Experts
Marvin
Marvin
Mike
