Question about Cyberhome DVD Recorder - DVR1600
I have bought Sony DVD+ discs when I put one in it asks me to format disc. It starts to format goes to 49% stops, on screen it says Blank Disc and on player it says root it then moves to 98% and stops it wont go any further I cant switch it off or eject disc I have to unplug it from mains. I have managed to format 2 discs and record on them ok. I have left it on 98% to see what would happen its now showing disc error. Any suggestions please
Posted by gaynorlatham on
3 Related Answers
Anonymous
SOURCE: No Disc
No, mine does take DVD-R, I tried DVD+R & nothing.
Now my player wont Record.
Wont power up & take in Blank discs.
Posted on May 06, 2008
Anonymous
  • 3 Answers
SOURCE: CYBERHOME DVD RECORDER DVR1600
I cannot say this with authority, since I own a 1200 model, but from what I've read of that model researching my own it's most likely the power supply. It is repairable if you or someone you know can solder. Here's what I found:
http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewtopic&t=2699
I did pretty much the same to my 1200, replaced two 2200uF caps with 35V versions. Make sure the rated voltage of the new caps is at least 16V! Higher is better. There's also a firmware update for that model, you might want to look into that too. Of course, you can't use it until this is fixed.
Posted on May 24, 2008
ericmorris69
Eric Morris
  • 75 Answers
SOURCE: I cannot format either dvd-r or rws with this machine.
try a single disk, but make sure format is not (-r or -rw; but +r or+rw )negative is mostly for computers, and positive is mostly for dvds and such; should find single at walgreens or wal-mart.
Posted on Apr 02, 2009
Disc error on hitachi camcorder
it may be that you need to format the disc this option should be located in the menu somewhere if it does not automatically ask you when putting a new disc in the camera. i hope this helps you.
Dec 23, 2012 | Hitachi Video Cameras
My RDR-GX300 Stopped loading & formatting blank discs
either a dirty optical pickup or a a bad optical pickup in the unit=pretty much has to be one or the other
Apr 07, 2012 | Sony RDR-GX300 DVD Recorder
Asking to format full disc
The simple trick is to put a disc into desktop DVD recorder. If Your DVD will be recognized, then copy all content to another DVD or camera. I've seen it before. Must work. Sincerely.
Sep 12, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
DOESN'T FORMAT BLANK DISC
use dvd-r or cd-r more universal usually dont have to format disc
Jun 02, 2009 | Cyberhome DVR 1600 DVD Recorder
My ps2 screen says 'insert a playstation or a ps2 format disc
t's not asking for a specific disc, it's asking for a properly formatted PlayStation disc.
This message could mean that any one of several things has happened:
* You are trying to play a Japanese disc on a US PS2, or vice versa
* You are trying to play a game that has been copied onto a CD-R/DVD-R
* Your disc is scratched/dirty/otherwise unreadable
* Your disc isn't a format that the PS2 recognises (i.e. CD, DVD, PS CD-ROM, PS2 CD-ROM, PS2 DVD-ROM, etc)
* Your PS2 is broken
Apr 02, 2009 | Sony PlayStation 2 Slimline Console
Camcorder won't format my DVD-RW disc
try a different brand of dvd recordable disks? maybe? that would be my suggestion before anything else...hope it helps.
Sincerely,
Rabeka Jo
May 15, 2008 | Video Cameras
Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
Dec 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Cyberhome DVD Recorder - DVR1600 Logo
Top Cyberhome Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
