Question about Acer Professional P211 21" CRT Monitor
Acer monitor lcd problem
I have a pretty new(1 1/2 months) old Acer computer with the lcd monitor. The computer itself comes on, but the monitor displays nothing. I have checked the signal cable at both ends, and they seem fine. The monitor says "no signal" everytime I unplug it, or turn it on and off. It also says no signal when I unplug and replug the signal cable into the computer itself. Any ideas?
Posted by sapphire7514 on
  • Anonymous May 11, 2010
    Do you have a seperate video card, which you might be accidentally plugging your video to the onboard one instead of the expansion card on the bottom?
richie46
    Top Expert:
  • Acer Master
  • 12,962 Answers
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Posted on Aug 31, 2017
5 Related Answers
Bogdan
Motoi Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
Anonymous
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
digiteyes
  • 110 Answers
SOURCE: No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Posted on Jan 05, 2008
Anonymous
SOURCE: Red Vertical lines on 15" Acer LCD Monitor
The LCD panel is going bad. Nothing is wrong with your computer. If the screen is not under warranty, then I would suggest replacing it with a new one
Posted on Oct 15, 2008
Anonymous
SOURCE: Display coming for 2 sec and then it goes off
Does it work well with other computers?
If you are connecting to a laptop, try switching display modes (like you would do for a projector)
Posted on Sep 03, 2009
I hav buyed a new acer v173 lcd monitor,and used upto 10 months till now.Lastday when i switch on my lcd,it showed the Acer logo , and suddenly the color of the screen changed,now the lcd works but i could...
Sounds like a problem with the video board of the monitor. I would contact Acer, since it less than 3 yrs old, tell them the problem that you are having get an RMA number and they will fix it for free. You only have to pay for shipping it back. Hope this helps.
Jul 29, 2010 | Acer V173 b Monitor
Acer AL175 TFT monitor is coming on but its very dim
The screen itself is starting to go bad which is why your having to turn up the brightness to 100% just to see something. Replacing the screen would cost more then the whole lcd monitor itself so its best to get a new one.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
My acer X193w+ screen turns pink. What is causing
laurie515, Gee, I hope it's a 'pretty pink' colour. Do you really mean that What was once WHITE or VERY Lite GRAY is now appearing pink??? Laurie515 you must tell us more. How old is this unit? 4-6 yrs? I suspect that the "Cold-Cathode-Fluorescent-Tubes" that are hanging on the rear of the LCD glass panel and provide white light, have over time, now become tired out. YOU WILL NOT FIX IT!! IT WILL ONLY GET WORSE. Here are some options. 1. Trade in for new if yours is >4yrs old. 2. Check for swapout program with ACER? This is only a dim Maybe thing. You send them yours +$50-$100 and they return a refurbished unit. 3. Find local TV/Monitor Repair shop that knows all about LCD monitor repair. there are also guys on fixya that do LCD refurbishing (new ccf tubes/inverter/smps) Do some web searches on LCD monitor failures and also visit youtube for vid clips of monitor disassembly if you want to see the insides of a typical LCD monitor.
Bye for now. I'm louie12fix on fixya or [email protected] aol.com
Sep 24, 2009 | Acer X193W LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
I have purchased a new Acer computer and Acer monitor, however when I turn them on they come up with the message 'no channel'. I have tried pairing up my old monitor with new computer and vice versa. On...
have u tried to see if the video card is inserted all of the way and chech to see if all of the pins on the end of the monitor cable are all straight and not bent and 1 more thing did u have to put anything into the computer when you got it
Aug 20, 2008 | Acer Computers & Internet
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Monitor goes black
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Problem with the acer al1916w
Sounds like the backlight or inverter might need replaced. It's pretty common on LCD monitors. It's best to call a local repair shop to do that unless you know what you're doing.
Jul 31, 2007 | Acer AL1916W 19" LCD Monitor
Lcd monitor acer
Here is a similar post: http://www.fixya.com/problems-solutions/t103544,p154505/Liquid-Video-MVBG619-Portable-DVD-Player-with-Screen.aspx Post a comment if you think this is not your problem, or if it doesn't help at all.
Jun 22, 2006 | Acer AL1911 19" LCD Monitor
Acer Professional P211 21" CRT Monitor Logo
69 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Steve Sweetleaf
Steve Sweetleaf
