Question about RCA 20V500T 20" TV
My RCA 20V500T turns itself on and off. I heard it might be a cold solder joint. If so where would it be?
Posted by blueysold on
alexander koshy
    Sergeant:
  • 174 Answers
The dry solder might be in horizontal section
Check the out put transistor pins / Driver cct. / FBT pins.
Posted on Jun 03, 2011
I have an RCA tv 21in truflat model number 20f514td. It's about 2 years old. About a month ago it started randomly turning itself on and off. It stopped for awhile then started up again, and now won't stay...
RCA is notorious for bad solder joints. If you are able, pull the back off, remove the main PCB from the bracket and flip it over. (ps: sorry, Unplug the TV!) Inspect as much of the solder connections as you can, reflow any cold, thin, or cracked looking joints you find. Many RCA TVs have been repaired by just this simple method. If you are not able or confident enough to do this, contact a local repair shop for service.
Mar 15, 2010 | RCA 20F514TD 20" TV
My RCA console tv has white horizontal lines accross screen, picture is very light and sound is ok, very frustrating. I know its an old tv, but appreciate any response. Thanks
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Jan 26, 2010 | RCA G35773SK 35" TV
In my old Rca The chanels don change I want input in chanel 91-92
this sounds like a cold solder joint problem.. around the tuner, you need to unplug the tv and take the back off the set .remove chassis and turn it upside down ... take a magnifing glass and ckeck the curcuit board for broken or dull solder joints the resolder them.... this should solve your problem good luck
Dec 23, 2009 | RCA Televison & Video
I have an RCA Truflat that began turning itself off today. Sometimes it will last 20 minutes, sometimes a few seconds. I'm broke..no way can I get it repaired..any ideas as to what's going on?
possible cold solder joint(loose connection). try the old method of picking it up and slightly moving it. hit it. if it seems to affect operation, just simple soldering on power supply and deflection will fix it. 50/50 chance
Nov 14, 2009 | RCA TruFlat 27F520T 27" TV
3-D picture with color lines
Seems TV has dry/ cold solder joints (loos connections) in convergence out section.
Please check cold/ dry solder joints in convergence out section in TV, specially on pins of convergence out ICs. resolder these solder joints and all would be fine.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
Black screen
BAD SOLDER JOINTS ON FLYBACK TRANSFORMER,RESOLDER FLYBACK,IT FIX MY PROBLEM
Aug 25, 2008 | RCA 20V500T 20" TV
20v500t turns on and it turns off by itself imediately
CHECK VALUE OF RESISTORS IN CRT BOARD,,,,AND THE 3 TRANSISTORS COLOR DRIVERS ....THATS AUTO SHUT DOWN FOR OVER VOLTAGE....DO YOU SEE RETRACE LINES BEFORE SHUTDOWN?IF YES TRY TO LOWER DOWN SCREEN FIRST ON THE FLYBACK TO SEE IF ITS GOING TO SHUTDOWN.....
Apr 17, 2008 | RCA 20V500T 20" TV
JVC 31" TV Vertical Screen Jumping
I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. 1 whatever you have heard is correct as whenever you smacked the lelt side it works fine. 2 you will have to check loose contact in vertical section. your vertical ic might be located at the left side of the tv. 3 check any connector is loose near vertival section. 4 any preset is loose in vertical section. it is a simple problem if you are not technical person please get it done by tech person. as your tv is old & if it is done by tech person tell him to replace all elrctrolytic capacitors in vertical section. good luck.
Sep 20, 2007 | Televison & Video
RCA 20V500T HALF PICTURE AND SHUTSDOWN
Try , Horizontal or Vertical output.
Sep 09, 2007 | RCA 20V500T 20" TV
Televison & Video Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
