Graco Nasalclear Aspirator - 1750335 Logo
Posted on Jun 03, 2011
Graco nasal aspirator not working - Graco Nasalclear Aspirator - 1750335
Pam Linzy
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 11, 2013
Pam Linzy
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4172
Points
Mine stopped working while in use. I stuck a small screwdriver into the nozzle with the two black rings. It started working. Hope this helps.
Where do I purchase the gray rubber ring?
Go to any good plumbing hardware store and the o-ring is 1-1/8" X 1" X 1/16" #81 O-Ring
Very dry nasal cavity. all the time
You are among many, many people who suffer from dry nasal passages. I suggest you do a search on the web; "dry nasal passages" or "dry nasal cavity". You will find loads of information and treatment remedies for this condition. Good Luck...
Battery direction
try putting the battery's deterrent ways up then press the power button untill it works, you wont break it
How do I use a bulb syringe nasal aspirator?
Hi! I found this helpful article about bulb syringe nasal aspirator on babycenter.com that should help you with your baby's stuffed nose. I hope it helps and that your baby gets well soon!
http://www.babycenter.com/0_how-to-use-a-bulb-syringe-or-nasal-aspirator-to-clear-a-stuf_482.bc
Nov 13, 2013 • Baby Care
What is nasal irrigation and how does it help with snoring?
Nasal irrigation works by flushing out your nasal passages. You can do it with a syringe filled with warm salt water or using a product specially made for this purpose.
In theory it unclogs your nose and helps you breathe easier at night. I find it super helpful when I have a headcold.
It might clear your breathing passages and reduce snoring levels. It's easy and cheap to try at home so you may as well give it a go.
About how much does a regular bulb nasal aspirator weigh? Are they heavy?
About 1 pound, definitely not too heavy. After all it has to be small enough to get into your LO's nostril.
Jan 31, 2013 • Baby Care
What is a nasal aspirator?
It\'s used to remove mucus from a baby\'s nose when it\'s congested. The most common types are simply bulbs that you use to remove the mucus. Others have plastic tubes, one for the infant\'s nose and the other you use to suck the snot out. Don\'t worry none of it gets in your mouth.
1helpful
I have a ast180ua381b when the coumper is turned of then back on most of the time it has to have the prosser removed than put back in to get it to come up and will work ok till it is turned off or...
Descartes drivers acre aspire ast180 ua381b para xp. use of nasal aspirator on dog ... can dogs have aspirin with codeine. acer 5530 schematic aspire ... how to restore acer aspire ast180 ud400a desktop. acre aspire 5100 5023 hard drive caddy ... acer aspire rc500 pc. problem med n?¤tverk skortet i min aspire t180 ...
Top Graco Baby Care Experts
Chaz
Chaz
Don A
Don A
ADMIN Andrew
ADMIN Andrew
Are you a Graco Baby Care Expert? Answer questions, earn points and help others
