Kitchen Ranges Logo
Posted on Jun 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
15 degrees celsius= ____degrees Fahrenheit the formula I have says to multiply 5/9 X (212-32) =5/9 X180 =100 the example is 100degrees= 212 degrees F. how do you multiply 5/9?
Robert Froman
Level 2:
  • Expert 127 Answers
  • Posted on Jun 03, 2011
Robert Froman
Expert
Level 2:
Answers
127
Questions
Helped
19704
Points
331
Tc = (5/9)*(Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit.
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 113 Answers
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
113
Questions
0
Helped
39389
Points
332
Multiply by 5 and then divide by 9.
Your formula seems sketchy to me.
Think with me and we will derive the formula without looking it up.
0 thru 100 degrees celsius represents 32 thru 212 degrees fahrenheit. There is a difference of 100 degrees between 0 and 100 degrees celsius. There is a difference of 180 degrees between 32 and 212 degrees fahrenheit.
Therefore, to convert from celsius to fahrenheit, a span of 100 degrees (given celsius) needs to fit into a span of 180 degrees (wanting fahrenheit). To cause this to happen, the temperature in celsius needs to be multiplied by 180 (the span we want) and then divided by 100 (the span we have).
However, 0 celsius is not 0 fahrenheit, it is 32. Therefore, the answer we get after multiplying by 180 and dividing by 100 will be 32 degrees lower than the actual answer. Therefore, 32 needs to be added to the answer.
Producing the following formula:
degreesFahrenheit = degreesCelsius multipliedBy 180 dividedBy 100 plus 32. degreesFahrenheit = degreesCelsius * 180 / 100 + 32. degreesFahrenheit = degreesCelsius * 180/100 + 32. degreesFahrenheit = (degreesCelsius * 180/100) + 32.
Often times people will reduce the fraction (an unnecessary step which hides understanding): degreesFahrenheit = (degreesCelsius * 9/5) + 32.
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
6274
Points
47
Example 5/9 x 180 would be written 5/9 x 108/1, then multiply straight across
5 x 180 = 900, 9 x 1 = 9 for a fraction of 900/9, or 900 divided by 9, which equals 100.
Converting 14 degrees c to f
To convert degrees Celsius to degrees Fahrenheit, you multiply by 9/5 and then add 32.
For example, 0 degrees Celsius would be 32 degrees Fahrenheit.
Another example, 100 degrees Celsius would be 212 degrees Fahrenheit.
14 degrees Celsius would be 57 degrees Fahrenheit.
Good luck,
Paul
2answers
2answers
How to change fehrenheit to Celsius
Can you give us the model number and brand name of the thermometer you are trying to change? If you have a calculator you can do the math. To convert temperatures in degrees Fahrenheit to Celsius, subtract 32 and multiply by .5556 (or 5/9). Here are some examples for you:
Example: Convert 26° Celsius (a nice warm day) to Fahrenheit
First: 26° × 9/5 = 234/5 = 46.8
Then: 46.8 + 32 = 78.8° F
Example: Convert 98.6° Fahrenheit (normal body temperature) to Celsius
First: 98.6° ? 32 = 66.6
Then: 66.6 × 5/9 = 333/9 = 37° C
Apr 25, 2016 • Home
How do we change F to Celsius.
How to convert Fahrenheit to Celsius 0 degrees Fahrenheit is equal to -17.77778 degrees Celsius:
0 °F = -17.77778 °C
The temperature T in degrees Celsius (°C) is equal to the temperature T in degrees Fahrenheit (°F) minus 32, times 5/9:
T(°C) = (T(°F) - 32) × 5/9
or
T(°C) = (T(°F) - 32) / (9/5)
or
T(°C) = (T(°F) - 32) / 1.8
Example Convert 68 degrees Fahrenheit to degrees Celsius:
T(°C) = (68°F - 32) × 5/9 = 20 °C
See webpage
http://www.rapidtables.com/convert/temperature/fahrenheit-to-celsius.htm
3answers
How to change from Fahrenheit to celcius
formulas and examples here
http://albireo.ch/temperatureconverter/formula.htm
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
What is 20 celsius in farenheit
Hi jujaramirez,
Have a nice day.
Here is the formula to compute farenheit to celsius and celsius to fahrenheit:
C is Celsius
F is Farenheit C = 5/9 (F-32
F = 9/5 (C+32
Let's try converting 68 degrees Farenheit to celsius 5/9(68-32)
Step 1: 68 less 32 is 36
Step 2: 5 divided by 9 is 0.5555555555555
Step 3: multiply the repeating decimal by 36
Step 4: your solution is 20
Now, convert 20 degrees Celsius to Farenheit to check your work.
9/5C +32
Step 1: 9 divided by 5 is 1.8
Step 2: 1.8 multiplied by 20 is 36
Step 3: 36 plus 32 = 68
Hope it answers your problem.
Thank you for using fixya.
Adieh
2helpful
What is the formula for 32degree celcius to fahrenheit?
the formula to convert degree Celsius to Fahrenheit is
Tf = (9/5)*Tc+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
to convert 32degree Celsius to Fahrenheit is
Tf = (9/5)*32+32 = 89.6°F
How much celcius is 32 fahrenheit?
32 Deg F. = 0 deg. C.
The following formulas apply in general:
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
