I was given a 26' GFM LCD TV that has a popping
Posted by skimask220 on
Rainer Mueller
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
A sound bar fixed that on my 60" Vizio. But in your case the sound bar may be more valuable than a new TV.
Posted on Jan 14, 2018
5 Related Answers
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: how to connect headphones if the tv doesn't have a headphone jack
Hi!
You can buy a rca to 3.5mm jack adapter from the link---
http://www.amazon.com/gp/offer-listing/B0002KR5Q0/ref=dp_olp_2
And it will help you to use a headphone with your TV.
Thanks
Rylee
Posted on Jan 23, 2009
Anonymous
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
Warf135
Warf135
  • 137 Answers
SOURCE: When I use the headphone output jack (to drive a powered subwoofer), the default internal speaker audio output is disabled, leaving me with only the subwoofer output. How can I use both the internal
Your best option is to use a seperate amp with sub output from the audio outputs on the back of your TV. use this amp to power the sub and a good pair of speakers, and you'll have quality sound.
It is possible to prevent the TV's internal speakers from cutting when you use the headphone socket, but it means going inside your TV, and if your not skilled, you can easily blow your TV (and yourself) up. You just need to re-wire the headphone socket on the TV to stop it cutting the internal spaekers.
Posted on Oct 06, 2009
Chi Chu
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
joeguest2
Joe2
  • 2080 Answers
SOURCE: My 26 inch Panasonic Viera
Check you USER MANUAL to make sure it is actually a headphone OUTPUT jack and not a digital INPUT jack.
If your tv does not have a headphone output jack you can always get an adapter that plugs into the red and white AUDIO OUT jacks in the back.
If you want to turn off your tv's speakers, go to the MENU.
Then go to AUDIO then select SPEAKERS OFF.
Good luck and please post back with how you make out.
Posted on Jan 24, 2011
Testimonial: "Found the manual & it is a headphone jack. No instruction on how to use it but after trial & error can now use headphones. "
The TV made a popping sound and went off , now no power. It's a DX-LCD26-09
check for blown fuse first , then burnt component parts at the power supply.
Sep 07, 2012 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Problems with headphone jack
Replace the headphone socket of the TV. It has contact fault.
Jul 12, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Am facing pblm wth my 26 inch lcd.. cant get sound output from the tv whenever i switched it onn, after several on nn offs of the power am getting sound output.. wat may the pblmm
The problem in that case is loose connection.Plss check first the wiring of the speaker then the speaker then the amplifier located at the board of your television.Try to fix wiring use soldering iron if there's a loose connection at the board..
Aug 21, 2011 | LG 26LX1D 26 in. LCD HDTV
We have an Magnavox 26mf337B and we have no sound
A TV without sound is awful. So let's take some steps to see if we can get it up and running.
1) Check your input cables - if you're trying to watch something through another device (cable box/satellite box/dvd player ETC) make sure that the cables coming from it are inserted correctly into the TV. If the device has it's own seperate sound output (VOL controls) be sure they are turned at least midway UP.
2) Check the settings on your TV - Sometimes TV's have a setting where you can select audio output (speakers, 2.1 5.1, stereo, etc etc) Make sure you have it set to output sound to it's own speakers and adjust the volume to an audible level.
3) Check the audio OUTput on the TV itself - Connect the white and red (or in some cases black and red) RCA jacks to the audio input on a stereo receiver. See if sound comes out. If this is the case, you have either selected the wrong output on your TV's settings, or your Tv's speakers are dead.
Hope this helps you solve your issue!
May 11, 2011 | Astar Magnavox 26MF337B 26 in. HDTV LCD TV
I have a Protron PLTV 32' LCD and its making crackling noise out of the right speaker.
Hello
If the crakling sound is from only comes from right speaker, it will be a speaker trouble. In some speakers, the voice coil will get damaged, and if so, this kind of distortion will occur. Replace the speaker with same type and diamensions. Note the 'Ohm' [resistance] of the coil, which will be marked on the speaker. There will be markings like 4Oms 6W, 8Ohms 10W or so. Choose the correct value of these. That is the only thing should mind when choosing speaker. OK.
Apr 20, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
GFM TELEVISION! THAT IS THE PROBLEM
have gfm 26" hdtv. remote was dropped on tile floora and no longer worked. no universal remotes will work - not even gfm's. went to remotes.com on the web. orig. remotes no longer mfgd. replacement unit is $39.95. worked right out of the box. batteries were in the unit. no muss, no fuss, no codes.
Aug 02, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Gfm tv universal remote code
Use the code for the sylvania tv. It worked for me!
Apr 30, 2008 | Televison & Video
Gfm remote code
I have a 26" GFM DVD/TV combo (v7tvdvd26) and used the LG codes listed for my cable box remote. I went through about 3 LG codes until I found one that works.
I've also read that Goldstar and Funai codes might work with GFM.
Feb 03, 2008 | Televison & Video
GFM Remote
I have DirecTV and one of the LG codes (10030) worked for me.
Someone also suggested Funai codes.
Jan 06, 2008 | Televison & Video
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
