Question about Texas Instruments TI-84 Plus Calculator
How do I fix my TI-84 Plus Silver Edition if none of the buttons will work?
Posted by koreantwin4k on
  • kakima Jun 02, 2011
    Are you sure it's the buttons and not the display. TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. If this is the case, turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
br4nt3
    Scholar:
    New Friend:
  • 42 Answers
Will the calculator turn on at all? If not, check the batteries first. There is a little coin battery that stores memory for the device behind where the regular batteries sit. This does not often fail, but could cause the thing to not power up. Note: removing the coin battery will clear any information stored on your calculator.
If the device is stuck in an infinite loop, or is unresponsive with the busy icon, try pressing and holding the "2nd", left, right and "on" buttons in that order and holding them all at the same time. This is the command to cancel whatever process the device is working and clear the internal memory (At least on the TI-89. I'm not 100% sure the command works on an 84).
Posted on Jun 02, 2011
None of the buttons on my TI-84 Plus Silver Edition will work
Does it turn on with a cursor, Have you tried a fresh set (all four) of batteries, Is there any corrosion/dirt on the battery contacts and the I/O port that you can see, Have you tried any resets?
Jun 09, 2014 | Texas Instruments TI-84 Plus Silver...
Cant find ! button
There is no such thing as a TI89 Plus Silver Edition.
If you mean the TI-89 or TI-89 Titanium, press diamond / (the diamond key below the 2ND key, then the divide key).
If you mean the TI-83 Plus Silver Edition or the TI-84 Plus Silver Edition, press MATH left-arrow 4 .
Dec 15, 2013 | Texas Instruments TI-84 Plus Silver...
Buttons on my TI- 84 Plus Silver Edition are not working. I can turn on the device but the buttons don't seem to work. I can't graph at all, or do anything.
Hi
if you can turn on and then click on the on button and this is the only ket that works then its an hardware problem and it can be fixed
let me know if you want to fix
[email protected]
Jack
Jun 27, 2011 | Texas Instruments TI-84 Plus Silver...
Everytime I turn on my calculator I get a messsage that says "TI-84 Plus Silver Edition 2.43 RAM cleared" and my calculator freezes and won't do anything. Please help!
Welcome to Fixya. To be able to fix the issue please click on the link below. It provides the steps on how to clear the error message.
TI-84 Plus Silver Edition 2.43 RAM cleared Fix
If you hve questions please let me know. Thanks for using Fixya.
Apr 08, 2011 | Texas Instruments TI-84 Plus Silver...
I have a TI-84 plus Silver addition and I have a row of buttons that do not work. Is there anything I can do?
you cant fix it on your own
it could be a fuse or the chip inside
i fix this calculators let me know if you want to fix
[email protected]
Sep 26, 2010 | Texas Instruments TI-84 Plus Silver...
How do I reset a TI-84 SIlver Edition graphing calcultor when the screen is frozen and none of the keys are working?
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries and turn the calculator on.
May 05, 2010 | Texas Instruments TI-84 Plus Silver...
Where do I find the comma button on the TI-84 siver edition?
The comma is located on top of number 7 key.
See page 5 on teh user manual to learn how to operate the keyboard on a TI 84 Plus:
TI-84 Plus TI-84 Plus Silver Edition Guidebook
Mar 16, 2009 | Texas Instruments TI-84 Plus Silver...
Waiting Please Install Operating System Now.
i finally fixed my calculator~
1. if you have a ti 84 plus silver, plus, or just ti 84, find a friend who has either a ti 84 plus silver, plus, or just ti 84. (as long as the number is the same)
2. link the two calculators together
3. using your friends calculator, press the [2nd] and the one next to alpha [x,t,o,n]
4. go all the way down to [send os]
5. send it to the other calculator and your problem should be fixed
Aug 27, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
611 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
