The vehicle should have a dip stick where you can check the transmission fluid, that same place where you pull the trani dip stick out is where you refill it. Remember to keep the vehicle running for a couple minutes before checking the level and do not turn it off, unless you filling it up or adding some fluid. If there is no dip stick then you will most likely have to go to the dealorship and have them take a look, in some cases depeding on model the dip stick will not be there.
Hope this Helps!
