Question about Panasonic TH58PX600U 58 in. Plasma HDTV
Panasonic TH58PX60U TV comes on for 5 to 15 minuets and shuts down with 4 red flashes on trouble code light. Is this the power supply board?
Posted by pnbtoritto on
Rocky
    Sergeant:
  • 302 Answers
Provably but neccessarily. It would be hard to explain if you don't have any technical. below is a panasonic blinking code that might help you. It is not always accurate. You would have to check the voltages of your power supply to be sure. You can find parts for this TV at. www.interliquidparts.com
Note blink charts can be different depending on the model and the year of the T.V.
1 - blink STV 5v sense DG Board
2 - blinks 15v SOS D Board
3 - blinks 3.3v SOS D Board
4 - blinks Power SOS P Board
5 - blinks 5v SOS D Board
6 - blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7 - blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
8 - blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 - blinks Panel Config. SOS
10 - blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
11 - blinks Fan SOS PB Board
12 - blinks Sound SOS H Board
13 - blinks Communication error DG Board with IC8001 (Pesks Lite 2)
Posted on Jun 02, 2011
Ivan Godzharov
    New Friend:
  • 112 Answers
4 blinks Power SOS P Board
Try opening it first look for some bad connections or so if they are none use a hair drier and heat the board looking for the place that creates the 4 blinking then use the hair drier on cool to cool the place and get this time little longer.
LED tv screen went black. How do I fix it?
Look at the website shopjimmy.com. They have trouble shooting videos to determine if it's power supply, led driver, led strip, or t con board.
Dec 06, 2015 | Panasonic Televison & Video
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Panasonic th-50pz800u shuts down and i can not turn back on, red light flashing 2 times, sometimes 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Will not come on. red light flashes 4 times
Never a good sign when you have red flashing codes
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-50A2000 50" HDTV
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I have no power to my 40 inch panasonic plasma tv. there is no red or green light
hi, no power has to do with your tv,s power supply, the trouble may be as small as a fuse or it may be the power supply needs replacing, this is your best bet, I would check that part first, if you had blinks or lights flashing then your problem would be with the other boards if your attempting to fix this set yourself it is dangerous voltages inside and you will need a service manual for trouble shooting, once you replace the power supply if something else dosent work then you will have flashing lights that will pin point the board affected. hope this helps. happy holidays
Dec 25, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH58PX600U 58 in. Plasma HDTV Logo
866 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
