The code Sd means that suds were detected. Generally this means you used regular detergent instead of the HE detergent. Less often it indicates that you used more detergent than needed for the load.
Remember to use an HE (high efficiency) detergent and to follow the directions for the amount to use in a wash cycle.
The washer should do a suds correction program to make sure that the clothes are fully rinsed. However, if the code remains and the wash cycle dial is flashing, set your washer to repeat the cycle with cold water without adding additional detergent. (Every portion of the wash cycle will be extra rinses.)
The manual for the washer is available as a PDF from Maytag's support site. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10092824.pdf is the manual for the MVWB750WB0. Additional manuals for MVWB750W washers are listed here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MVWB750W&siteCd=MT_EN_US .
I hope this helps.
Hi
Error
code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8
minutes and the water valves turn off. After 4 minutes the "Sd" error
will be displayed, and then 4 minutes later the F21 error code will be
displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the
drain hose and make sure it is not plugged or kinked. If the drain hose if fine
then unplug the washer and check the electrical connections at the pump and
make sure the pump is running. Check the drain pump filter for foreign objects.
To access the drain pump and filter remove the front kick panel and trace the
drain hose to the bottom of the washer, drain pump would be located there. If
you are not able to access it, then replace the back panel as well. Plug in
washer or reconnect power. If the issue is still not resolved then you would
need to replace the drain pump. Hope this helps...please post
back for further assistance.
Daniel
