Question about LG LHD459EL Dehumidifier
There
are several reasons this may be happening. The 2 primary reasons are
the humidity extraction level is set to high. Lower it to 35% . The
lower the setting, the more moisture/humidity is extracted from the air.
The higher the setting, the less if any moisture/humidity will be
On most humidifiers the fan runs almost
constantly while in operation. The idea is to continually move the air
around and when the unit senses a rise in humidity, above what you have
it set on, the compressor will turn ON to extract that humidity.
The
2nd thing that causes the problem is a dirty of clogged intake air
filter. Which is easily solved by removing and cleaning the filter.
Which should be done at least every 2 weeks, while the dehumidifier is
in operation.
I said there were 2 reasons. Actually, there is a
3rd. Not enough clear air space all around the dehumidifier. A minimum
of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jun 02, 2011
My unit is about 1.5 years old. Ran fine initially. Now,the fan runs, the compressor kicks in but, no water is colletcted. I cleaned the front filter and made sure the unit has plenty of clearance. I also elevated it to a counter top next to the kitchen sink. Still no extraction of moisture to the bucket. What's wrong with the unit?
