Question about Stanley Utility Knife
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Posted by diggsboz on
Ginko
  • 19,396 Answers
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Posted on Jun 02, 2011
  • diggsboz Jun 04, 2011
    I clicked on your link called "Stanley knife disassembly" and it took me to answers for refrigerators and turbo tables. ???
Stanley manual
First never take a tool apart if don't know what you are doing, second go to the Stanley web site and you can buy or download a copy of the one you need.
Mar 08, 2014 | Stanley Hand Tools
How to change stanley 99E blade
Hello, Go to this youtube website too see video on changing the blade.
Jan 01, 2014 | Stanley Bostitch 10150 Straight Handle...
How do I open the calculator to change the batteries?:s
If there are no small screws on the back to come out, it's a 'clip' type and will need a small thin blade to pry the sides apart to open.
carefully use a knife blade to pry it open.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 13, 2011 | Texas Instruments TI-82 Calculator
I have a Bissell powerfoforce Bagless. A friend just gave me her older one, she is off to buy a newer model. I have been through every vacuum cleaner you can image, dirtdevil , kirby, etc and on and on. Sh...
There are at least 18 different models of Powerforce. There are too many parts and pieces to be able to describe what you need without seeing it. I suggest paying your local vacuum shop to put it back together. It may need a new belt, brushroll and/or filters. Do scrimp on these things if you want it to work properly.
Mar 14, 2017 | Bissell 6594 PowerForce Bagless Upright...
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Stanley carpet cutter model 10-525 fell apart. I need to know correct assembly.
This is a terrible tool took it apart to get the blade out of the handle and haven't been able to get it back together again.
Oct 22, 2010 | Stanley Garden
STANLEY QUICK POINT BLADES...CAN'T FIGURE OUT HOW TO CHANGE.
There is a SLOT in the end of the knife. Simply insert the strip of new blages in to the slot and you are ready to go.
Good luck. :)
Apr 25, 2009 | Stanley Hand Tools
Stanley  Utility Knife  Logo
2,000 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
Wiscon Envirotech...
Level 1 Expert
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
