Dakota Scout KVM Switch Logo
Posted on Jun 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New PC has been used to upgrade old PC. The problem is the PC wont install the Switch device properly. i have added two PS2-USB converters, as new PC does not come with PS2 slots. PC is Windows XP. Model number 1016-02. Do you know please of any drivers?
Prashant Sharma
Level 3:
Genius:
  • Master 1,127 Answers
  • Posted on Jun 02, 2011
Prashant  Sharma
Master
Level 3:
Genius:
Answers
1127
Questions
0
Helped
237345
Points
3825
Hi
Most USB mice at the moment come with a small converter to use them with a PS/2 port. Those don't
need a driver. I just plug them in.
I had to get a new computer and don't have the instructions on how to install the keyboard . is it possible to download the from somewhere?
if it is new it will be a USB keyboard.
25742882-mbdszjf5eloqzagipkamzl0z-5-0.jpgthe computer will have a usb port for non technos that is universal serial bus it looks like
if it looks like
ps2
25742882-mbdszjf5eloqzagipkamzl0z-5-3.jpg then you have to line up the black plastic with the purple socket on the back on the pc . If the P.C doesn't have a purple socket you will need a usb keyboard or a PS2 to USB converter plug thingy.
How to convert ps2 cunnector to USB connector in ncx 2000-xp
You can buy devices to convert USB to PS/2 like this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812150091
You might just be better off upgrading to a newer PC if you're able to do so. Good luck!
How do I connect a usb mouse and keyboard to ps2 kvm switch?
usb to ps2 converter, the sell them for like 30$ but you can go to radioshack and buy a keyboard for that with the little adapter
I have a SK 6000 keyboard with a touchpad/mouse. I have 2 questions: First: the mouse/touchpad connection is a nine-pin com port how can I convert this to PS2 and/or USB (the keyboard connection is...
Get a "Serial to PS2 converter" or a "Serial to USB converter" from the market. Now connect one and of the converter (the 9 pin side) to the keyboard and the other side to the PC.
Make sure that all USB functionality is enabled in the BIOS, especially USB Legacy Mode.
Yes in window 7 it gives some issues as you need to get the proper driver software for windows 7.
Need to the USB drivers for my xi2000 hand scanner. I'm going from the old PS2 connector to the USB connector, I'm using a keyboard cable to convert from a PS2 to USB. Do I need the drivers also, to make...
You may not need drivers; try plugging your scanner in after Win boots. If you get a box stating that WIn has 'found' a new device, it may install a basic driver for USB.
Otherwise, check the scanner mfr.'s website for drivers that you may need.
1helpful
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
9helpful
4answers
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
2answers
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Top Dakota Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Dakota Computer and Internet Expert? Answer questions, earn points and help others
