Actually there should be a little door you can access at the bottom front to clean out your pump filter, I'm including my washers pictures. 1) You first open the little door at the bottom. You do not need any tools, just something to drain the water in to. 2) Unscrew the hose closure, put your hose down into the drain bucket. Drain all the water out, you may have to empty the bucket so you can get the hose lower next time. 3) Next unscrew the filter itself. Get anything out inside the hole, in my case it was a toothpick, I take a paper towel and dry out any grit or hair. 4) Put your hose closure back on, it is held in a clip, Then screw the filter back in. That's it. I would also recommend cleaning out the drawers that hold soap, bleach and fabric softener. Also clean around the rubber ring, it will help your washer last longer. Hope this helps you
Remove hoses. Pull plastic tab out either with your finger or a small pair of pliers. Note that after you remove the filter, look inside the hole and you will see another filter mesh. Use either a spray bottle and water and a Q tip to clean or carefully remove the mesh by prying up on the EDGE (so you dont put a hole in the mesh). It actually comes out quite easily. Both hot and cold inlets each have TWO mesh filters.
