Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Need a Hayward pool pump manual. Don't know how to hook up filter and pump.
Posted by theresaaj on
5 Related Answers
Anonymous
SOURCE: accurate pressure for 2 hp ag hayward pool pump
the psi range is normal and will fluctuate with the cleaniness of the filter. Depending on wether or not you have a Sand filter or an Earth Filter, you should periodically backwash(for sand) and "bump" for the earth filters. You will notice that the psi will lower back down to the lower psi range. This indicates that your water is flowing freely with little resistance.
Posted on Jun 13, 2009
james aurienne
  • 93 Answers
SOURCE: intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Posted on Jun 16, 2009
james aurienne
  • 93 Answers
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
A Miller
  • 8404 Answers
SOURCE: hooking up five hoses to my hayward pump/filter
Your system has a suction side and a discharge side. Skimmer and bottom drain hook to the suction side. Returns (discharge) return via chlorinator or other sanitary system and heater if appropriate, to ports in the side of the pool.
Posted on Jun 03, 2010
Hayward vari-flo sp0710xr50 install manual for piping
I don't have a manual but basically the intake of the filter connects to the area around the grids. The inside of all the grids connect through a manifold and pipes to the output port of the filter. The pump output should be piped to the return piping of the pool. If you have a heater it should be connected between the output of the filter to the return piping of the pool. If you have a chlorinator the output of the heater it should be connected through a metal-free check valve, into the chlorinator and then to the return piping of the pool. I hope this helps.
Aug 13, 2011 | Hayward EC-40 DE Pool Filter with pump
Show how to hook up hoses to sand hayward filter
Here is a copy of the users manual for these pool filters. Page 5, specifically, should help you because it has a diagram of the filter and where the hose connections are. It should have everything you need to get it set up properly.
http://www.backyardcitypools.com/images/hayward/side-mount-filter-manual.pdf
Jul 12, 2011 | Hayward SAND FILTER, PRO SERIES
My filter has only been used for 2 months, it seems like there is sand on the bottom of pool, I just had new liner put in because the sand crystallized last year and I couldn't get it off. The filter...
Hayward should stand behind their filter. If the unit is only two months old, the seller should be helping you. If there is sand in the pool, it is because on the bottom of the filter is a distributor which is tubing with many thin slits. The slits are small enough that sand can not get through. If a piece of the tubing breaks or if it is not installed tightly, sand will continue to get out and into your pool. If you Google Hayward, I'm sure customer support will be able to help you.
Gary
Jun 30, 2011 | Hayward SAND FILTER, PRO SERIES
How long does the sand filter need to run?
According to Hayward Pools, it should run anywhere from 30 Minutes to 1 Hour, depending on the gallon content of the pool you are sanitizing. You should read the manual of your particular model and verify the sand filters pump and CFM capabilities. Manuals can be downloaded at the following link:
http://www.hayward-pool.com/webapp/wcs/stores/servlet/ProductInfo_10201_10551_14502_-1___I#FiltersSand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Hayward Pro Series Sand Filter -36" Tank
Need to know which is inlet and which is outlet connections
Take a look at the owners manual for these pool filters below. They have a diagram that should help you figure out where to hook your connections up.
Jun 19, 2010 | Hayward Pro Series 21" Above Ground Pool...
Hooking up five hoses to my hayward pump/filter
May 31, 2010 | Hayward SAND FILTER, PRO SERIES
Hooking up filter to pump and pool
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
Pool need to know how hoses hook to pool
from the skimmer to inlet pump -from outlet pump to in let filter -from out let filter back to pool return
May 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
141 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
