SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
SOURCE: unsilence
Hello gc0273,
Make sure that both radios are using the same Interference Eliminator Code. The situation you describe sounds like one radio has a Interfernce Eliminator Code activated and the other radio does not.
To access the Interfence Eliminator Code setting on this radio press and hold the MENU button until the code starts to flash, then use the + or - keys to adjust the setting and press the PTT to save it.
Best Regards
Agent Ken
Go Ahead. Use Us.
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either + or – to turn On or Off.
3. Press the PTT to confirm or MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
SOURCE: my walkie talkies wont transmit
Go on line. Search for the operators manual. It should give you the information you need.
