Question about Toys
Do I need a special table to set up rokenbok?
Posted by mapolley on
michaelcox91
    Problem Solver:
  • 13 Answers
No, I have a set and it can go on anything, just don't let the trucks fall off.
Posted on Jun 02, 2011
How do you keep massage tables clean?
There are special covers that you can buy for your massage table that are machine washable. Try this website for some ideas http://www.bestmassage.co.uk/uk/accessories/massage-table-covers.html
Aug 13, 2012 | Furniture
Need the instructions for conveyor belt
Here are the Rokenbok plans/manuals: http://www.rokenbok.com/hard-hat-area/building-plans-plan-books
Feb 16, 2011 | Rokenbok Conveyor Company Start Set
I cant find the manual on the Rokenbok website. it is not listed with all of the Old systems.
We just uploaded this building plan at http://www.rokenbok.com/hard-hat-area/building-plans-plan-books. Make sure to refresh the page if you don't see it.
Rokenbok Toy Compan
Jan 29, 2011 | Rokenbok Rc Fire and Rescue _
The Rokenbok monorail will not move forward or backward. And the basket on the monorail moves on its own without stopping or without touching any buttons.
We had the same issue here. The motor would run but the drive rollers would not move. I took the entire engine assembly apart and determined that the drive gear (pinion) on the motor shaft had slid out and disengaged from the other gear(s). I pushed it down to re-engage it and it works. A spot of glue where the gear meets the shaft seems to hold it in place. Good luck - lots of screws.
Jan 22, 2011 | Rokenbok Monorail Metropolis Start Set by
I have a Powermatic 66. The table top not aligned w/blade. I can't get a wrench into the 1 1/2" slots in either the front or back to loosen/tighten the 4 bolts. Is there a special wrench that fits these...
The factory never intended for you to touch the 4 bolts you mentioned. The table top is set parallel with the blade by loosening the 3 bolts (2 in front and one in rear on the outside of the cast iron table where it meets the base. These are easily accessible by sitting on a milk crate and looking up. They are 3/8 bolts with 9/16 heads.
Apr 02, 2010 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have an old rokenbok sweeper truck that just will no longer work. I've changed the batteries and checked the connection on the radio control, but still nothing.
check and make sure there is no corrosion on both the truck and the remote.If thats not the problem,then you might have something that needs to be replaced inside the truck.
try it in a different area to make sure nothing is interrupting the signal.
Aug 28, 2009 | Rokenbok R/C Power Sweeper
"I have a Rokenbok R/C Power Sweeper and the wheels on one side don t work"
I don't know how this ended up saying it was a Rolls Royce..........This is regarding a toy...I have a Rokenbok R/C Power Sweeper and the wheels on one side don't work
May 12, 2009 | 2006 Rolls Royce Rolls Royce Corniche
I need to change the blade on my 10 in. tabel saw,
OK. first of all unplug it. Then remove the plate that surrounds the blade. Wrenches came with the saw so hopefully you still have them.
You need two special wrenches which are sold at any sears hardware store if you don't have a set. The only thing to remember is that the outer nut has reverse threads so turn it clockwise to loosen it and counter clockwise to tighten it. Note the direction the saw teeth point in and duplicate that with the new blade.
Get back if you have any other questions.
May 03, 2009 | Craftsman 10" Table Saw
Toys Logo
148 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
