Question about Panasonic Microwave Ovens
Microwave combi oven/grill Timer can be set as usual but whatever longer time is set the function always switches off after 99 seconds. The time remaining stays on the clock display but the macine has to be restarted and will run for another 99 seconds before stopping again still with time remaining on the clock. Machine has given good service for 4 years but it is frustrating to have to stand by the machine to do anything which takes more than 99 secs!
Posted by razat on
  • razat Aug 19, 2008
    Hard reset did not fix unfortunately.
    I did not give the detail of the fault or the machine accurately I apologise. The machine is a Sharp Platinum Collection combi
    Microwave /Grill / Convection Oven model no R-937(IN)F
    031207209
    However the timer is set for any function for more than 59 seconds, it will only run for 59 seconds (Sorry I said 99 last time) So if the timer is set for 2 minutes cooking time, the start button will have to be pressed at 2.00/1.01/0.02 ie 3 times to complete the 2 minutes. If the one minute timer is pressed it also runs for 59 secs and has to be restarted to complete the last second which remains on the display.
    Thanks in advance for any help you can give.
    Regards Chris
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    Let us know if the hard reset does not fix it.
    Otherwise, it may possibly be a damper-related issue. This is a convection model, right?
    Please reply back with your model number as well.
acmservice
    Sergeant:
  • 268 Answers
Sounds like issues with the mcroprocessor on the main timer board. Contact https://encompass.com/ to see if it is available
Posted on Aug 16, 2017
5 Related Answers
SOURCE: Microwave cuts out after 23 secs
may be inverter circuit or related control circuit any drysolder, may be magnetron
Posted on Dec 18, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Help, my Panasonic NNA724M Combination
This is an inverter model, and when they stop after 20 seconds, it usually means a problem in the high voltage section, either the inverter or the magnetron.
If you don't have experience troubleshooting high voltage inverters, I recommend calling a pro.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 02, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
Posted on May 09, 2008
Anonymous
SOURCE: Panasonic Microwave Combi Oven - convection heating not working on timer
fu*k u
Posted on May 27, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may even send you a replacement magnetron. GE Customer Service is here.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
How set clock on oyster microwave and grill?
Oster Microwave Oven Operating Instructions
  1. Press the "Clock" button once, then the correct number buttons to set the desired 12-hour time. ...
  2. Press "Timer" to set the timer function. ...
  3. Press the number pads to select a cooking time. ...
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. ...
  5. Select "Speed Defrost" to defrost food quickly.
More items...
Oster Microwave Oven Operating Instructions ' Hunker
https://www.hunker.com/13407971/oster-microwave-oven-operating-instructions
set clock on oyster microwave and grill Google Search
Jun 24, 2018 | Microwave Ovens
Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 08, 2009 | Emerson MW8777W Microwave Oven
I have a panasonic NNA883w combi microwave oven. The microwave part has stopped working. The unit dows not turn switches off after three seconds without warming anything. The oven and grill elements still...
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these inverter-based models.
You can find an authorized Panasonic servicer here.
Sep 25, 2008 | Panasonic Microwave Ovens
Belling CJ ss 25 Microwave Combi
I would suspect a bad magnetron or a loose connection at the magnetron's terminals or possibly another high voltage part (such as a shorted diode or bad transformer).
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Otherwise, I would contact the manufacturer or your local microwave / appliance repair center for service.
Good luck.
May 29, 2008 | Microwave Ovens
May 08, 2008 | Sharp R-963 Convection/Microwave Oven
Help, my Panasonic NNA724M Combination Oven will no longer microwave. I can set the microwave going but after 20ish seconds the microwave stops and timer is replaced by the clock, without any audible...
Apr 01, 2008 | Microwave Ovens
Microwave Ovens Logo
90 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Ekse
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
