Question about Optimus Audio Players & Recorders
I have an Optimus STA 825. One channel or the other cuts out randomly and simultaneously the overload clicks in and out. It clears up if I pound on it; but returns later. I resoldered all the connections on the printed circuit board but to no avail.
Posted by gordon_d_woo on
  • 4 more comments
  • gordon_d_woo Jun 03, 2011
    Thank you for the info on two protection circuits. The major problem is that it's intermittent and almost anything can start or stop the amp. I hear a chattering sound in the amp along with the overload light flickering in unison; then it stops: maybe for a long time. I moved it to work on, turned it on, it worked fine and has done so all day. I checked the thermal protection by cranking up the volume; it started distorting and finally turned off. Turned back on just fine. Can you tell me where these circuits are located so I can poke around? I have been trying to get manual or schematic without any luck. Any additional info would be greatly appreciated.
  • gordon_d_woo Jun 04, 2011
    It was useful to find out there is more than one protection circuit
    Excellent! Thank you for the info.
Anonymous
    Genius:
  • 1,157 Answers
Hi gordon_d_woo,
The receiver has two special protection circuits:
1. The thermal overload protection circuit automatically turns off the receiver's amplifier if it overheats.
2. The overdrive protection circuit automatically turns off the amplifier if too much power is being drawn from it.
If a protection circuit turns off the amplifier, the PROTECTION indicator comes on.
If this happens, press POWER to turn off the receiver's power. Check for proper ventilation and proper speaker connections, and be sure the speakers have an impedance of 8 to 16 Ohms.
The protection circuits usually reset in only a few minutes, so you can turn on and use the receiver again. The circuits seldom take longer than 30 minutes to reset.
If the receiver stops working and the PROTECTION indicator is not on, please replace the Fuse.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 02, 2011
Azrael SRL
  • Optimus Master
  • 11,800 Answers
This is the basic schematic of the final amplifier in your unit
http://www.diy-electronic-projects.com/p38-2N3055-Power-Amplifier
the only difference being that your unit uses 2SB775 as finals.
In it the overload protection is done by measuring the current absorbed by each final transistor - this is dependent of the load given by the speaker, the amplitude of the input signal and the temperature of the bipolar transistor.
If the problem gets fixed by banging on the case then either you have a bad connection either at the speaker jacks or in the connections on the board - one of the copper tracks might have fractured and to find it you must inspect the entire board with a magnifying glass - or one of the final transistors no longer makes a good contact to the radiator - find it, take it off completely, clean the old silicon past ans add new one and refit it properly.
Posted on Jun 03, 2011
Optimus STA-3500, display is so dim you can't read it without a magnifying glass. No "dimmer" adjustment visible unless there is a special code........?
The manual might have the code to adjust the display screen optimus sta-3500 manual on google and on the companies official website too.Or call or email customer service then.
My Optimus STA 3760 Receiver will not play any sound on tape monitor, and will only play the right channel on the phono setting. What could be wrong with it/ how do I fix it?
Chemically clean all of your input selector switches and see what happens. If still have issue then one of your amps is in need of repair.
No sound on left channel on home stereo optimus sta-795 will changing fuse out restore sound
Not likely! Suggest swapping input connection, red RCA connector to white and white to red and see if problem swaps speakers.
If still left channel bad swap speakers left to right see if problem follows speaker.
Check balance adjustment and confirm that it is set to the middle!
Check all other inputs and confirm always no left output.
The goal is to confirm that the left channel is defective!
The service manual is MS3102101 would normally be available from Radio Shack.
Check for defective capacitors or failed solder joints on the PC board. These units are repairable even by DIY however replacement recievers are relatively inexpensive.
Hope this helps?
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
Optimus sta 795 manual
I need service manual for STA-795
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Top Optimus Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
NOEL
NOEL
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
