When washing clothes...load size dont matter,setting dont matter...when it gets to the spin cycle it stops...you reset it & it continues to finish they cycle....but clothes are soaking wet when done
A top-load washer tub is usually supported by four suspension rods. If one of the suspension rods becomes dislodged or breaks, the control board may stop the spin cycle several times to try to balance the clothes. Suspension rods will often come in a set of four and it is recommended to replace all four of the rods at the same time to reduce uneven wear.
There is a small arm that contacts a switch in the tub area, When the tub wobbles and strikes it you get an error code OL=overloaded. The arm is bound up and must be lubricated.
does ur washer shake & move also? if so, it may be that the loads r too small. especially with top loaders, when the machines not full, the clothes r not evenly distributed and that could do it. if u stop the cycle and evenly distribute the clothes, it should stop. hope that helps.
Sounds like one of the internal suspension/dampening units for the drum unit has broken or become unattached. Am not certain what this machine has but removal of top and rear cover should allow you to inspect the items and arrange replacement as required.
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix? From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct? If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spinsetting to Spin/Hang dry seting and start the cycle.It should take about 10 min complete.Does the Spin Only cycle complete with no clothes in the wash basket? Some handy links if you are going to DIY.........Service Manual for reference.
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
i have a kitchenaid washer that does the same thing! it has flooded my entire house on more than one occasion & i mean really flooded! i absolutely hate mine. it gets stuck right before the rinse cycle & then won't drain the water from the wash cycle & starts refilling to rinse & never stops. it just overflows continuously. i personally think that it's a sensor or something. i had a repair man come out when it was still under warranty & they claimed there was nothing wrong w/it. i putting it on the curb this weekend & getting a new one. i don't think that i have ever hated an appliance as much as this one!!!
