If you do not know the Wireless Password(PIN), you will need to Log in to the router and set it. Make sure your computer is plugged in to the router with an ethernet(internet) cable. Do not use wireless connection.
Open Internet Explorer, or your favorite browser, and in the address bar where you type the name of the website you want to visit, type the following: http://192.168.1.1
When prompted, use the following password:
Username: (Leave Blank)
Password: admin
If you cannot Log In using that password, you will have to reset the router to its default settings. To do this press the Reset button on the back of the router for 30 seconds. Once it comes back up, try to Log In again using the password above.
Once you successfully Log In, look for the tab that says 'Wireless" or "Wireless Security". Set the security type to WAP. Enter at least a 10 character Wireless Password(PIN) that uses at least 1 uppercase letter, 1 lowercase letter, a number, and a special character.
Apply the change and then give your house guest the Wireless Password(PIN) you created above.
When you say pin do you mean the encryption key? and if so what operating system is on the computers in which are currently connected to wirelessly ? and did you try going to 192.168.1.1 and typing in your admin info? (default is usually admin for name and no password or password as password) and going to wireless then security and you should see something written next to the generate option and hit generate and that shall be hte key
