The front pannel on the mother board will be indicated some ware in the mortherboard the function is tha a3.3v must be shorted to ground for the computer to start if you have a multi tester then check the pin for voltage and short in with 0v the power switch will be different in motherboard the sequence of the front pannel is 10 Pin Panel connector (IDE LED, Power LED, Power Switch, Reset)
