When the choke is fully closed your choking the fuel out,, thats why when you give i t gas it dies , its not supposed to run with the choke on and getting fuel , use the choke only until the motor warms up to operating temp,, then open it,, and you should be fine,
Thanks for the response but I made a mistake in the request. It stalls when the choke I opened, not closed.
no worries,, if thats the case,, you need to turn the idle mixture screw in about a 1/4 turn, that should fix the problem,, if it doesn't,, pull the plug and see if its wet and black, if so put the idle screw back where it was and replace the plug , its not firing fast enough to burn all the fuel so its flooding itself out.
Thanks again, I'll give it a try.
one other thing,, make sure the vent in the fuel cap is clear,,
