Question about JVC RX-6018V Receiver
Lost the remote for my JVC RX 6018v. How do I find the remote code. Even the Directtv remote won't work with it.
Posted by jsaurage on
2 Related Answers
Anonymous
  • 1665 Answers
SOURCE: NEED REMOTE CONTROL CODES FOR RCA RCU1010 REMOTE TO CONTROL A JVC RX-D205S
Try this
Code 188 for JVC SAT
http://remotefinder.rca.com/
Posted on Jan 20, 2008
Anonymous
SOURCE: JVC RX-884V 5.1 Channels Receiver Problems &
4171, 4176, 4149,4141
Posted on Sep 26, 2010
How do I get the digital audio cable to work from my tv to my JVC rx-6018v reciever
To start, make sure your receiver supports "digital" in the form of coax (rca) or optical type to their respected video inputs.
Mar 31, 2014 | Audio Players & Recorders
How can I hook up my jvc rx-6018v to a gemini xga-2000 amplifier?
you can do it a couple of different ways, depending on what you're trying to do with your set-up.if you're trying to do something different than what I describe here, add a comment.
for independent volume control (each unit contols volume to a set of speakers independent of each other) use the rca 'tape' out of the jvc into the rca inputs on the back of the gemini.this puts a stereo signal from the jvc to the gemini. if you want your gemini to power your subs, get an rca y-splitter (single female to double male) and a single rca cable, hook single rca cable to sub out of jvc, connect y-splitter to gemini rca inputs, and single rca to y-splitter.
Mar 05, 2013 | JVC RX-6018V Receiver
JVC rx-668v universal remote code
just try go www.fitness.manualsonline.com or www.remotecodelist.com or memorex.com
if You would not FIX IT. i recomend you to exchange by a NEW Ones, the SYSCON inside from the remote control had been faulty see the diagram.
God bless you
Jul 25, 2012 | Televison & Video
Do you have the code for programming the volume on a DIRECTTV remote?
go please to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 10, 2012 | Daewoo DTQ-13V5FC 13" TV
How do i turn off the linear pcm on a jvc rx-6018v
The nature of a source's digital bitstream is automatically detected at the receiver. Look at your unidentified source and ITS manual for that answer.
http://www.retrevo.com/support/JVC-RX-6018VBKJ-Receivers-manual/id/315ag011/t/2/
See the box on page 14.
Sep 23, 2011 | JVC RX-6018V Receiver
I lost my remote and can't change the channel on the control panel. It is on channel 02 and it won't change even when I hit the channel+ or channel- button.
Hello.
Your problem is stuck keys in your T.V. It usually just needs cleaning, BUT it is hard to clean, because you gonna have to open up the whole TV. I advice you just buy a new remote from JVC or just buy a "Universal Remote".
Jul 18, 2011 | JVC AV-32D305 32" TV
5.1 surround sound will not work. Only showing digital auto and linear pcm.
You should try pressing the surround on/off button or the speakers on/off button
Jan 02, 2011 | JVC RX-6018V Receiver
Subwoofer problem
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your reciever feed at the entry point to your system.
Dec 23, 2009 | JVC RX-6018V Receiver
Reciever won't stay on
Do you have too much of a load on the amplifier? Or as SallieJohns mentioned, is it getting adequate ventilation?
Apr 02, 2008 | JVC RX-6018V Receiver
JVC receiver
Did you check impedance value and wattage on speakers you want to add to receiver?
Sep 30, 2007 | JVC RX-6018V Receiver
JVC RX-6018V Receiver Logo
Top JVC Audio Players & Recorders Experts
xxxxxx xxx
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
